Which torque wrench?
Old Feb 21, 2010 | 07:41 AM
RoadHog659's Avatar
RoadHog659
Default Which torque wrench?
Several threads have discussed the benefits of having an inch-pound and a foot-pound torque wrench in the toolbox, but which ones? I have looked on-line and found prices ranging from $20 to $300 and specifications from 10 - 250 (inch, foot, whatever), 1/4", 3/8", 1/2" drive. I'm not a mechanic, but with a 2001 FLHT I occasionally have to tighten a bolt now and again. Can you guys steer me toward a decent quality set at a reasonable price?
Old Feb 21, 2010 | 07:52 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Go to Harbor Freight. I picked up a very nice set of torque wrenches in both in/lbs and ft/lbs for a very nominal price. It made me feel all warm and fuzzy inside not spending a bazillion dollars for these, but I'm sure there are some that need the petting of havin spent the equivalent of the national deficit buying theirs somewhere else. LOL!!!
Notgrownup's Avatar
Notgrownup
Craftsmen is always a decent tool and good warranty...the size depends on what you have most in your current toolbox as far as socket size is concerned but i would steer towards a 3/8" size because you can buy adapters to make them fit 1/4" and 1/2"...More than likely you have 3/8" sockets laying around. If you have the money to spend you can also look at snap on, Matco, Cromwell etc....The one i use is a cheap one from Advance aut that i paid $20 for...it's a foot/lbs but for tigntening lug nuts and heavy weight fasteners accuracy is not as critical as the Inch/lbs. I would spend more money on the latter if the funds were limited. Like the previous poster said also...Check places like Harbor Freight and Northern Tool and Equipment.
Old Feb 21, 2010 | 08:03 AM
UltraKla$$ic
Talking
HERE
HERE
HERE
COUPON
Old Feb 21, 2010 | 08:12 AM
SpiderPig's Avatar
SpiderPig
I have the same set from Harbor Freight. 1/4 in lbs 3/8 ft lbs and 1/2 ft lbs. And they work very well. I am with ya Ultra Kla$$ic, feel the same way about the bazillion dollars for some others!!!! .......
Old Feb 21, 2010 | 08:16 AM
ddm502001's Avatar
ddm502001
Having been a wrench for over a quarter century, be careful as to your purchase of torque wrenches. These need calibration on a less than frequent but on a frequency basis or the damage one can cause is at times devastating.
I prefer name brand units from local tool dealers and return them for cal every year or so, inactivity is harder than continual use, my inch and foot pound units are Snap-On but MAC tool is as good for the money. I have had a few fail recal and the warranty on them from the bigger manufacturers is well worth the money spent.
Old Feb 21, 2010 | 08:17 AM
UltraKla$$ic
I'm just messing with those that have expensive ones, certainly nothing wrong with that. I'm just a cheap bastage that's all.....LOL.
Old Feb 21, 2010 | 08:23 AM
JimTJr's Avatar
JimTJr
Hey NOTGROWNUP,, Sears, (Craftsman) won't warranty their Torque Wrenches for more than a year. They do NOT have the Life time warranty.. been there done that,, got a little pissed at them. It is a hand tool, I know they won't warranty an electric saw, drill ect.... Anyway, it depends on how accurate you feel the tool needs to be. Torque wrenches are a required PMEL (Calibrated) item in the military tool inventory, but of course some things are probably more torque critical on a 2 BILLION dollar air plane!
I think a home use torque wrench the most important thing is if all bolts are evenly torqued, like on a jug/head ect.... other than that. I think the "Armstrong" torque wrench would suffice most times....(Unless your seating a bearing or something, then you don't want to get it too tight/loose)
Old Feb 21, 2010 | 08:24 AM
nocarb's Avatar
nocarb
I have 3 torque wrenches. Snap On 40-200 inch pound (QD2R200), 20-100 foot pound (QD2R100) and a 50-250 foot pound (QD3R250).
I prefer Snap On tools, they are not for everyone. For most people Craftsman will be just fine.
Old Feb 21, 2010 | 08:27 AM
JayStronghawk's Avatar
JayStronghawk
I found Craftsman to be fine for the little use I need on a torque wrench .. Have inch lbs and foot lbs both...
