Squishy front brake help
Old Feb 22, 2010 | 08:19 PM
clayharley's Avatar
clayharley
Default Squishy front brake help
Newbie here, I have a 02 Road King and my front brakes are squishy to a point where I'm almost pulling all the way to get it to brake. The pads are good and I just bled the brakes, but no help. Any ideas? Thanks,
Old Feb 22, 2010 | 08:36 PM
dawg's Avatar
dawg
Clean the pistons.
Old Feb 22, 2010 | 08:44 PM
Agnes the dog's Avatar
Agnes the dog
after trying the caliper cleaning, get some new braided brake lines. you'll notice a huge difference.
Old Feb 22, 2010 | 08:45 PM
dswansbiker's Avatar
dswansbiker
My 02 was getting pretty squishy too. I upgraded to braided front brake lines. Squishy no more.
Old Feb 22, 2010 | 08:46 PM
Jday53's Avatar
Jday53
Bleed them again but try some braided lines big improvement
Old Feb 22, 2010 | 08:48 PM
big ern's Avatar
big ern
my 03 was the same, had grease from the factory in the calipers. rebuilt the calipers and the problem was gone.
Old Feb 22, 2010 | 08:54 PM
Road Ranger's Avatar
Road Ranger
What dog said...
Old Feb 22, 2010 | 08:57 PM
BLKBAGGER's Avatar
BLKBAGGER
I use speed bleeders. They allow you to bleed the brakes in minutes. Check your brake lines and make sure they are in good shape. Braided lines are far better then stock.
Old Feb 22, 2010 | 09:09 PM
brewcrew1632's Avatar
brewcrew1632
Stage III
check the brake fluid. depending on the type of fluid it uses, dot 4 or 5, the color will tell you if it needs changed. check the seal on the resivor. if the fluid is off of the original color changing the fluid, can help. just bleed the line and add new fluid as you go, so no air gets in it. once you see the color change close the line and see if that helps. try not to get the fluid on the bike, it may damage the paint or crome. if dosnt work change the line and re-check.
Old Feb 22, 2010 | 09:16 PM
clayharley's Avatar
clayharley
As far as bleeding the brakes and making sure I'm doing it right I'm using silicone dot 5 brake fluid I got from pep boys. When I bleed the brakes I do bleed one side at a time right? I pump the handle several times, sqeeze and hold, unscrew one side until fluid comes out, the handle goes to the grip, I tighten, then pump and start over. Once I do one side I go to the next? Am I doing this right? Thanks
