Problem with adjustable backrest install
Old Feb 26, 2010 | 04:34 PM
mastery's Avatar
mastery
Default Problem with adjustable backrest install
I'm near the end of a four hour install with an adjustable rider backrest (talk about a pain, took 3 hours to get it to install with the midframe heat deflectors on my 08 Ultra, and a few beers to boot). Got everything buttoned up, put the backrest in the bracket, and low and behold, won't stay adjusted (locked).
Took seat off, and noticed that where it mounts to the bracket next to the gas spring, the steel "see saw" where the tip of the cable slides in to is not moving all the way down to the lock position. Cable is long enough, but it looks like I need about 1/2" more of the braiding to stick out of the end so the "see saw" stays down (right now, the length of steel cable inside the flexible cable keeps it pulled up, which keeps the seat from locking into a adjusted position.)
Question is, before I take apart the deflectors and the adjustment handle to see if there is a way to give a little more slack to the steel braiding, anybody know if there is some way to adjust it on the adjustment handle? I hate to take it all apart, then spend another 3-4 hours trying to get it all put back together (only 2 hands, but you need 4 and have to hit the angle of the bolts exactly perfect with no room to work).
I'm using kit # 52622-03A, and the cable is part #52479-01A. Once I get everything installed, it seems to fit perfectly on my 08 Ultra...except for the problem. Like I said, the cable it self has plenty of slack, and operating the adjustment handle does show the steel braided cable inside it to move easily...just the handle is hitting it's stoppers, and seems like it needs to go back into it's cavity another 1/2" or so. I'm hoping to find out if there is a way on the handle to give back a little more steel braiding before I take it all apart.
Any thoughts?
Old Feb 26, 2010 | 05:48 PM
JonnyD's Avatar
JonnyD
Jeff, I feel your pain. It's been a while since I installed mine, so I can't quite remember exactly what your talking about without seeing a pic of your trouble spot. I spent several hours installing mine, shortly after I bought the bike, got it all working right (after much frustration) and then went for a ride with my wife. Came home and took the thing off and sold it. I'm not sure if you ride with your significant other much, but those adj. backrests don't leave a lot of room for a passenger, and are kinda bulky. I went with the Mustang backrest and it's 100% better, and more user friendly for both rider and passenger.
If you have a pic, maybe it will help. I'm sure someone has ran into the same problem with theirs and has a more recent recollection of their install. Thanks for the cam write up, by the way, it will be next winters project.
Old Feb 26, 2010 | 06:04 PM
mrsr71's Avatar
mrsr71
I went through the same ordeal. You MUST route the cable as straight as possible. No tight bends/turns. It will work if you do this.
Old Feb 26, 2010 | 06:50 PM
atrain68's Avatar
atrain68
That's right you have to route the cable just right. But also check the adjustment lever. Occasionally the plastic part on the cable, not the metal end, comes undone from from the switch housing. The lever won't work right if that happens.
Old Feb 26, 2010 | 06:56 PM
lawnmower man's Avatar
lawnmower man
I'm glad I didn't have the deflectors, took me about an hour to install. Quick question: are you actually sitting on the bike with your back against the rest when you are adjusting it or just trying to do it with your hand?
Old Feb 27, 2010 | 04:02 PM
mastery's Avatar
mastery
Well, I took it off, and even laid it straight to the bracket, and tried the adjustment lever, with no bends in cable. Same problem, same amount of steel cable showing. So, it's not a bend/turns thing, looks like it was just made a tad short.
My "fix" to this was to connect it to the "see-saw" lever, and not connect it to the fixed position holder next to the gas tube on the bracket. I held the see-saw piece up, put seat where I want it, and let go of the see-saw. It's now sitting in the position that is comfortable to me (took a few seat install/uninstalls to get it positioned where I want it).
I gotta say that HD could have made this whole accessory much easier, and perhaps they did with one of the new backrest kits. I got an older one from years ago, and had to do some mods, but it works now. Just not adjustable.
Oh well, I won it for $50 shipped off of eBay last year, and it's been sitting in the garage waiting to be installed. For $50, I can't complain. I hear the Mustang is a much easier install, adjustable as well, and if I ever have to get another one, I'll try the Mustang. Thanks everybody for your assistance.
And JonnyD, hope it helps.
Old Feb 27, 2010 | 04:06 PM
JonnyD's Avatar
JonnyD
Well, I got the mustang seat to go with the backrest so install consisted of sliding it in the backrest slot in the seat For $50 it was worth a try, glad it's fixed.
Old Jan 7, 2020 | 07:08 PM
Dewercs2's Avatar
Dewercs2
Stage II
Hi guys,,, reviving an old thread I found while googling for a fix to my 06 Glide. I also had a back rest that wouldn't adjust. I read a few posts from different pages where I saw that someone had removed the piston and placed into their press which got it working again.
That got me to thinking... a little lube onto the piston housing, pair of pliers and remove the cable. Press the arm a few times and my piston popped!
I'm assuming leaving it in one position for so long it got hung up. A couple drops onto the housing allowed it to drip onto the piston between the bolt. by pressing on the release arm and using a flathead screwdriver stuck into the backrest holder and working it back in forth... it popped loose.
Hope it works for you all!
pb
Old Jan 8, 2020 | 01:59 AM
LQQK_OUT's Avatar
LQQK_OUT
That might have been me. Here is the post.
https://www.hdforums.com/forum/touri...l#post17691437
jc168
2014-2024 Touring Models
Nov 19, 2023 06:20 PM
immusicman
Nov 7, 2014 09:24 PM
mogood
Aug 23, 2008 11:26 AM
swilcoxaz
Jul 4, 2008 08:33 PM
hittman
Feb 7, 2008 09:57 PM
