Need help with a broken fairing
Old Mar 8, 2010 | 10:52 AM
Brockmeister's Avatar
Brockmeister
Default Need help with a broken fairing
Hi all. The plastic stem inside my fairing broke off. There isn't enough plastic to the standoff inserted. Can you heat a piece of plastic to get it to stick on there? What's the best course of action to fix this puppy?
Old Mar 8, 2010 | 11:06 AM
dawg's Avatar
dawg
You can try some of the plastic weld epoxies
Old Mar 8, 2010 | 11:15 AM
Overdoo's Avatar
Overdoo
Default Broken Standoff
Try going to radio shack. They sell circut board standoffs in aluminum. You'll need to square off the broken post and then tap it for the standoff thread (male end). The standoff must have a 1/4-20 thread (female end) on the end for the screw coming from the fairing. You can buy these things in varying lengths. You'll need to see what's avaiable then trim off the broken piece accordingly. I hope that helps
Old Mar 8, 2010 | 11:32 AM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
there is a product called lord fusor (same stuff h/d recomends for bag extensions) its a 2 resin product and is tuff as nails..used it for the same issue on my scoot..worked great
Old Mar 8, 2010 | 12:00 PM
Brockmeister
I have the 2 standoffs and threaded insert for the repair.However, there isn't enough base to drill the hole for the insert. Fathertime where did you get the lord fusor epoxy? Let me know. Thanks.
Old Mar 8, 2010 | 01:34 PM
fathertime's Avatar
fathertime
Default lord fusor
bummed it off a local body shop..they use it a lot for bumper repairs etc
Old Mar 8, 2010 | 01:40 PM
Brockmeister
I ordered a tube from a local vendor. Now I just need to get a plastic dowell and chop off a piece. I already have the insert from HD.
Old Mar 8, 2010 | 02:25 PM
fathertime's Avatar
fathertime
i had the original piece that broke off and just glued it back in place with the fusor
Old Mar 8, 2010 | 03:20 PM
Brockmeister
I HAD the original piece once upon a time...Of course now that I'm motivated to fix the damn thing, I can't find it. I already chopped the bad part off. Maybe I can go to Home Depot and get a piece of plastic.
hdking13
Apr 8, 2014 08:42 AM
simpkinst
Jul 16, 2012 02:16 AM
VandalENG
Aug 31, 2010 10:49 PM
stro1965
Feb 3, 2009 07:57 PM
Maple Leaf Hog
May 2, 2008 03:52 PM
