Heated gear controllers on ultra
Old Mar 15, 2010 | 08:51 PM
NYBagger92's Avatar
NYBagger92
From: LI, and New York, NY -- N 40 44.985 W 73 00.910
what jacket liner are you going to use?
my gerbing jkt liner has two inputs..
one is for the liner
the second is a run through for the gloves.
Old Mar 15, 2010 | 08:59 PM
m50's Avatar
m50
I am going to use the Gerbing jacket liner and thought I only needed a dual cont if I was using pants also.
Old Mar 15, 2010 | 11:23 PM
dougbk's Avatar
dougbk
You may find out that you want the dual controller because your hands may need more heat than your torso, but the liner and gloves will work off of a single.
Old Mar 16, 2010 | 10:27 AM
DMcBiker's Avatar
DMcBiker
I also mounted my dual controller on the tank console. I used a heavy duty rubber band to go around the console. The belt clip from the controller just hooks right in; the power lead goes right under the seat to the battery. Easy to hook up and easy to adjust with big gloves on.
Old Mar 16, 2010 | 10:33 AM
NYBagger92's Avatar
NYBagger92
with the newer Gerbing jackets.. you may need a "Y" splitter to accommodate the power distribution in the jacket if you use a single controller, and also use gloves.
Old Mar 16, 2010 | 06:50 PM
Punjabi Rider's Avatar
Punjabi Rider
We have portable ones with dual controls but don't use em often too much to monkey around instead we just use on off switch easy to plug in and go.
jimgpayne
2014-2024 Touring Models
Mar 27, 2019 09:45 PM
ClutchHD911
Feb 4, 2019 07:42 AM
flashracer
Dec 22, 2018 08:45 AM
XL1200C_0112
Dec 21, 2018 05:48 PM
jimclaypool
Feb 8, 2010 08:41 PM
