Cam sound???
Old Mar 18, 2010 | 09:16 PM
atrain68's Avatar
atrain68
I was thinking tensioners too. If you took your cam chain tensioners apart did you put them back together correctly? If the little metal piston is installed upside down, the tensioner won't work.
Old Mar 19, 2010 | 01:50 AM
thereal142's Avatar
thereal142
While it is making the noise at idle, bike on jiffy stand, take your boot or something and apply forward pressure to the outlets of each muffler. First one, then the other. The rubber hangar bushings can interact with the chrome straps that go through them. I change mine every year. The sound will follow up the pipe and you will swear the bottom end of your motor is falling apart.
Old Mar 19, 2010 | 02:03 AM
1sweetglide08's Avatar
1sweetglide08
Did you install a cover over the gear shift linkage...that will rattle?
Bowtiejc
Mar 17, 2019 06:51 PM
Peter Quinn
Milwaukee Eight (M8)
20
Sep 14, 2017 04:04 AM
Tri-Glide
Exhaust System Topics
May 3, 2017 12:46 PM
IAFatBoy96
EVO
30
Jun 18, 2010 06:07 PM
