Cruise control problem
Old Mar 21, 2010 | 01:34 PM
Geoff of NV's Avatar
Geoff of NV
Angry Cruise control problem
Before I jump into it I thought I'd ask your advice. I've got a 2006 Electraglide Standard with the HD Cruise Control that has been working just fine for about 60,000 miles. Yesterday after slowing for traffic I hit the resume switch and it took off way past where I had been running it. Tapping the brake wouldn't shut it off so I had to turn it off at the main switch. Tried it again a few minutes later and it seemed to be ok right up to the point where it wicked full on again. I've got the Maint manual and parts manual but not the electrical manual.
Recommendations?
Old Mar 21, 2010 | 02:11 PM
mazz's Avatar
mazz
i had a similiar problem it was my throttle sticking
right hand grip was not moving smoothly
Mazz
Old Mar 21, 2010 | 04:08 PM
abate1's Avatar
abate1
I had a kink on the cruise cable just as it went inside the cable housing and would hang up and sometimes accelerate hard. Changed the cable which was very easy and all is well again. Mine would always shut down with a brake activation.
Old Mar 21, 2010 | 06:31 PM
orbiker's Avatar
orbiker
Recommendations?
I would look for a loose connector or a wire that has rubbed thru and grounded.
Old Mar 21, 2010 | 06:34 PM
1flhtk4me's Avatar
1flhtk4me
It does not hurt to take a look at the cable and also lube it.
Old Mar 21, 2010 | 06:35 PM
SBJJC's Avatar
SBJJC
search the curse control threads. there will be one for finding out any and all error codes relating to the CC. that will tell you if it is the CC or not. if there is no error, you can check your connectors and then throttle. if nothing pans out, you make have to take it to the dealership.
Old Mar 22, 2010 | 06:16 AM
MTGlide's Avatar
MTGlide
Check your fuses. I had a fuse blow (I don't recall which fuse) and the CC would not turn off by hitting the brake. I had to use the switch to dis-engage the cruise.
Panhead Bob
Jul 9, 2017 11:31 AM
JC650
Jun 23, 2011 06:39 PM
Ghosteh
Mar 19, 2011 03:49 AM
bsam450
Jul 27, 2010 04:05 PM
nb472
General Topics/Tech Tips
Oct 18, 2006 12:42 AM
