Anyone running 11.5" Progressives?
Old Apr 3, 2010 | 10:21 AM
eglinski's Avatar
eglinski
Default Anyone running 11.5" Progressives?
I switched from the stock 12" Road king Custom shocks to Progressive 430's 11.5"
I notice the bike bottoming on normal road bumps. Riding solo @ 180 lbs
Does this sound right? It does not sound like the rear tire is hitting the fender...rather that the frame or kickstand somewhere under the motor.
Any info or comments would be helpful, thanks
Old Apr 3, 2010 | 01:53 PM
eglinski's Avatar
eglinski
Bump up... Anyone?
Old Apr 3, 2010 | 02:07 PM
Dyna Mike's Avatar
Dyna Mike
I ran 11.5 progressive shocks on my '98 dyna wide glide.
I also lowered the front with progressive springs and lowering kit and found that she bottomed out on the smallest of bumps.
The bike looked great and handled better but by jaysus it was uncomfortable, it looked dead cool but the wife used to bounce a lot and it was not far off a hard tail I used to have.
So yep, tis normal.
Old Apr 4, 2010 | 04:28 PM
jitterbug's Avatar
jitterbug
I run those shocks on my 2006 SG. They bottomed out untill I adjusted them about 5-6 times. I finally got it so they glide ove most bumps and only on the worst do they bottom out slightly. I have a detachable tour pak and ride 2 up. Keep turning the top adj until you find the right spot
Old Apr 4, 2010 | 04:46 PM
DanD's Avatar
DanD
I have em on my 02 dyna,usually run em at the second notch from the bottom,no problems when I'm solo,and these are the regulars,not the heavy duty.about 220 pounds here.
Old Apr 4, 2010 | 05:51 PM
texas steve's Avatar
texas steve
had the same problem on my 07 SG, went to Progressive 12.5" MUCH better!!
Old Apr 4, 2010 | 08:08 PM
LEGENDCHROME's Avatar
LEGENDCHROME
I run 11.5 440 hd's on my 07 king, it took some adjustment but it rides great.
Old Apr 4, 2010 | 11:31 PM
slvr_bullit's Avatar
slvr_bullit
Runnin them on my 08 Street Glide. Just required some adjustment... no problems at all afterward. over 5000 miles on them without bottoming out
Old Apr 5, 2010 | 12:00 AM
eglinski's Avatar
eglinski
well, that is good to hear, I installed the 430's with the bigger chrome end up...as I read that it didn't matter. Is that correct?
Turning the steel end clockwise = stiffer and the lines on the shock body go down...I'm at 1 line now...solo and I might have to go fully clockwise for 2 up.
I bought these used on the forum, called Progressive and I do have the standard duty springs as well, so that is a possible option as well.
*Road King*
Feb 5, 2014 04:17 PM
hogster1961
Nov 10, 2012 03:28 PM
Hot Harley Girl
Sep 21, 2012 11:06 PM
Overdoo
Nov 28, 2007 09:19 PM
bub2007
Sep 7, 2007 06:30 PM
