I ride in the 2200-2800 range, maybe down to 2000. But below 2000 the power falls off, out of its power band imo. Even gently rolling on the throttle at this rpm and you can feel the pounding that the engine bottom end is taking. Yeah lugging is not good.
That cool sound is the bottom end of your motor being beat to ****. BTW I only used the word assumption because boogerdude did, and I used all caps because I figured theres plenty of folks that have trouble hearing based on the number of riders I see lugging their bikes around town.
Bottom line, everybody rides how they want to. And everyone has an opinion, so.....
I didn't call you a schoolyard name, nor treat your opinion with any disrespect. Just asked a question.
Hmm... So you intenionally lug the motor, becaue you like the sound?
Geez.... With your super performance 107" I hate to tell you but your are putting more wear on it by lugging then revving. Its yours, ride it like you want to, and enjoy it while it lasts...
No, I do not intentionally lug the engine because of the sound, I intentionally go by the sound so I don't lug the engine.
It is not a super performance 107", it is an intentional, conservative performance 107" with a cam selected for a very broad power band (wide lobe separation, medium duration) for a two up touring bike.
There are many internal stresses on an engine, example - at wide open throttle and peak torque RPM you have the highest stresses on some components, at the high RPM shift point you have the highest stresses on other components and at peak HP, other components. A given engine with a mild cam is NOT percieved to be lugged at 2000 RPM, yet that same engine with a radical cam IS percieved to be lugged at 2000 RPM even though it is producing less torque with less internal stresses due to the radical cam producing less engine effeciancy at that RPM. With all of the variables, who out there is going to tell me or anyone else when they are lugging there engine.
normal cruising is 2500-3000 mostly at 2700. Shifting around 4000 getting up to speed. Playing around pushes close to 6000 on the shift. I rarely use 6th gear unless I am really rolling.
Kinda glad I don't have a tach, I always try to shift before the rev limiter and never use 6th below 75. Lugging the motor doesn't sound cool, and I don't understand why somebody wouldn't want to be in the powerband, if headlights get too close behind me i'm gone, I also don't sit along side a semi waiting for the tread to come flying off one of the tires. I feel safer and in control when i'm riding in the powerband (around 2500 rpm at least imho)
"An rpm and speed at which, no matter the amount of throttle input, the engine will not accelerate."
That being said, there are many different riding styles and many different engine configurations. I definitely try to keep the engine in the 2500 to 3000 in anything above 4th gear as that is closer to the actual peak torque and the engine will respond better to throttle inputs and give best mileage. Lower gears, it will not hurt to be below those rpms and the engine will still provide decent acceleration due to the gearing.
I have done economy testing at 60mph, both in 5th and 6th, and 5th will provide better mileage as there is less throttle needed to maintain speed.
For the most part, these new engines are pretty durable and running them a bit lower in the rpm range is not going to hurt them as long as you are not trying to do WOT runs in 6th at 1500 rpm, then you are going to hurt something. But, in general, it is better to run them closer to peak torque for efficiency and longevity, and peak torque varies greatly from stock to modified engines.
