Rpm
Old Apr 11, 2010 | 09:19 PM
  #41
Dalton's Avatar
Dalton
You can find the definition from Caterpillar, Cummings and Mobile Oil to mention a few and there are many others. A simple Google search will get you many results and what I stated is stated the same and in may variations, but essentially the same.
And yes, if peak torque is at 3500 rpm, the most efficient rpm to operate the engine would be in that range, that is why older model bikes are geared much higher, new bikes have the advantage of peak torque at lower rpms due to larger displacement and better design so the bike can be geared lower.
In general, and note that I used these same words in a previous post, engines can be run under peak torque without issues as long as they are not lugged.
Old Apr 11, 2010 | 10:15 PM
  #42
geargrinder's Avatar
geargrinder
Reply - Even using their definitions, that leaves many variables from different engines and conditions. Example, I can pull my engine down to 1200 RPM in any gear and accelerate, on a level surface. Personally, I do not agree with their definitions.
Reply - At peak TQ RPM is where the engine is most efficient at cyl filling, cyl combustion pressure, brake specific fuel consumption (BSFC) etc, but not usually the best RPM for part or full throttle cruising fuel economy. Especially at part throttle, as RPM increases mechanical efficiancy decreases and if that peak TQ amount is not needed, it is usually better to select a gear that decreases the RPM, providing ample TQ is still available to prevent lugging. I fee; that the earlier TC 88s" could also have benefitted from the 6-speed concerning fuel economy and longevity.
Reply - yes I did note and agree, I think we are basically agreeing on all of this.
Old Apr 11, 2010 | 10:38 PM
  #43
ezryder62881's Avatar
ezryder62881
Couldn't tell ya--thats why I have ears. Dont need a tach to tell what the engine's doing. Sure is lots of "experts" on here though.
Old Apr 12, 2010 | 06:42 PM
  #44
dbr1990's Avatar
dbr1990
Default This forum is for support, not for big ego's
There seems to be alot of flaming going on here.........Can't we all just get along?
Ride it like you want.....you make the payment.
Old Apr 12, 2010 | 08:01 PM
  #45
Dalton's Avatar
Dalton
Hmmm, not a lot of flaming in the thread (well maybe just a little), but a lot of opinions and good discussion. You haven't been around long enough to see a real flame war!!
They can be real entertaining as long as you are not involved.
Old Apr 13, 2010 | 01:20 AM
  #46
VibratingPotato's Avatar
VibratingPotato
I know that when I ride my sport bikes at low speeds, the engine heats up faster if I'm doin' 4k rpm or so, than if I keep it under 2k rpm.
I assume my Potato bike heats up quicker at low speeds with more rpm.
If you spend much time in slow traffic, remember 3k rpm makes more heat than 1800.
Old Apr 13, 2010 | 01:23 AM
  #47
Mike's Avatar
Mike
na....no flaming going on here. Forum members disagree at times. It's all ok as long as it doesn't degenerate into insults or name calling. This is a fairly civilized forum, and the members take a lot of pride in that.
Old Apr 13, 2010 | 01:35 AM
  #48
Spartacus55's Avatar
Spartacus55
ditto dbr it's your dime ride it like you stole it or lug away to your hearts content like i said it's your dime. don't let anyone tell you how to ride your scoot. opinions are like a-holes everyone has one and they all stink
Old Apr 13, 2010 | 04:29 AM
  #49
ryanl's Avatar
ryanl
Originally Posted by boogaloodude
I didn't call you a schoolyard name, nor treat your opinion with any disrespect. Just asked a question.
I may have been a tad childish taking liberties with your name. I apologize.
Old Apr 13, 2010 | 06:34 AM
  #50
Sandcrab's Avatar
Sandcrab
I like 2500 because it is easy to keep the needle of the tach centered.
