True Duals question
Old Apr 17, 2010 | 07:58 AM
  #31
oldbiker771's Avatar
oldbiker771
I wanted the same thing you did, and am kinda cheap. All I could find for head pipes were 400 bucks. Then I found Full Sac. They use parts of your old system. For 179 you get 2 plasma coated (or black) pipes, a rear exhaust gasket, and a mandrel to round out your pipes for a good fit. Less than an hour to install if you do it their way, took me longer cause I took the whole system off and replaced rusty hardware, pulled the cam cover to check the tensioners, etc. I combined their headpipes with Krome Werks 3.5 in mufflers ($459) Very satisfied. At cruise, a comfortable rumble that sounds like an HD should. No radio interference if you have one to listen to. Full throttle acceleration gives a throaty roar with no sharp high freq "blatting" that I hate so much. Both companies make a nice product, 16 ga. metal, mufflers well chromed. I recommend them both. If you plan to use stock mufflers, make sure you open the baffle on the left one as they come with more restricted flow than the right one from the factory. I found no loss of tq on the butt dyno. I have a stock 88 with Big Sucker, the aforementioned pipes, and a stage 1 download.
Old Apr 17, 2010 | 08:24 AM
  #32
VETERAN75's Avatar
VETERAN75
got some rinehart td's on mine. Made by bub. They have a good little rumble to them and are loud when I get on it. Sound pretty good on the road to me.
Old Apr 17, 2010 | 08:31 AM
  #33
weezo's Avatar
weezo
I just put on Rinehart TD's and at first felt a loss at the lower end. I was really happy with the sound, but not sure with the loss. I adjusted the 5,10 and 15% throttle values on the PC V up a bit after talking with Keith at Fuel Moto. Now it has great low-end power and sounds even better.
The Rineharts are loud so you might want to factor that into your decision.
Old Apr 17, 2010 | 08:53 AM
  #34
Dalton's Avatar
Dalton
Originally Posted by NoCoLoco
I think true duals are overrated and 2-into-1 is not necessary with anything less than a Stage II upgrade. JMO
On basically stock bikes, true duals will slightly decrease lower end tq but will you notice - maybe, maybe not. Are they overated, well based on what? If it is the look and sound you want and you are not chasing numbers - go for it. A good two into one is not "necessary" in any case, it is all up to what you want. HD's head pipes really aren't all that bad (excluding stuffing a cat in the 2010's) and just going with the right slipons and a good tune can be a nice gain.
Originally Posted by grbrown
I think what we can also guess is that TDs will work better with some engine builds than others. ...
You are right, the larger the engine, the better they work but will still not get you to the same place as a 2-1, but will in a lot of cases outperform a 2-1 at upper to high rpms, and that is what you see on your dyno chart. If you had a chart of say, the 60kpa area at 2500-3000, you would find tht most 2-1 really outperfomr true duals. It is all in what you want, the sound, looks and performance, are all personal choices. Many go with TDs for the looks, or sound, and there is nothing wrong with that.
Old Apr 17, 2010 | 10:12 AM
  #35
oscarg's Avatar
oscarg
I have the jackpots 2/1/2 headers fuel moto has dyno sheet showing small increase in power and Jamie told me 70to 80deg cooler and that on a non cat 09
Old Apr 17, 2010 | 10:14 AM
  #36
Merlin's Avatar
Merlin
Default Just a day at the beach.
Not only does it open up the engine area, looks cleaner and sounds deeper...
The girls like it better too!
Now there's a selling point!
Old Apr 17, 2010 | 08:38 PM
  #37
J2X's Avatar
J2X
I recommend the TRUE DUALS. HD dyno test were positive with about about 0.12 more HP.
Old Apr 18, 2010 | 12:58 AM
  #38
qtrracer's Avatar
qtrracer
I don't care who you are that's funny right there, a whole .12 of a hp.
Old Apr 18, 2010 | 05:46 AM
  #39
luc.who's Avatar
luc.who
+1 it is funny, I hope he didn't have to pay dyno rates to confirm that...
Old Apr 18, 2010 | 07:41 AM
  #40
gwcrim's Avatar
gwcrim
Originally Posted by luc.who
I think what you are hearing from those of us with the TDs are, we can still keep up with our riding group and really enjoy the looks, sound and lower heat on the right side.
It comes down to what you really want.
Good luck with your choice.
Great point. I guess I'm trying to work out that equation of how much effect on power am I willing to put up with to lose the heat on my leg. I love to agonize over these things.
