True Duals question
OK, let's shift gears...... would a SuperTrapp 2/1 do anything to cut down on the right leg heat situation?
I do think my next purchase is going to be the V&H HIPO 2/1 black ceramic coated setup.
http://forums.supertrapp.com/showthr...light=supermeg
I'll quote the post by the moderator:
"Our 2:1 is pretty quiet by 'industry' standards. Performance wise is by far the best choice.
True Duals, just by design, seperating the exhaust pulses, increases noise over the stock head pipe. Perfomance wise, true duals are more for looks than anything. The stock head pipe will provide a slightly better/broader spread of power over the duals, as well as being quieter."
Coming from a company that does nothing but make exhausts, I'll put a lot of faith in his answer.
Bumped into a guy on the weekend with the IDENTICAL bike/engine mods as me apart from the headers, which are 2-1-2, and he is getting more top end hp as well as a clean hard pulling bottom end. He said he was in my shoes when he was running true duals and since the change to 2-1-2 "it's a new bike"!! My next move is going with a 2-1-2.
2-1 would do the same thing I presume.
I also have a '07 softail running a 103" stage 2 running V&H True Duals and it it runs flawlessly. Off the lights it's identical to my friends 103" stage 2 in his 2010 Street Glide running factory headers (with cat in-tact) with slip-ons. So from what I've learnt, the higher the mod's are on your bike the more it matters you run a tuned set of pipes.
On a stock bike I don't think you wouldn't notice the difference. I do love the look and sound of the true duals though..
When I had my Sportster, I tried over a dozen different exhausts on it. I know the seat of the pants dyno is a very bad dyno. I won't comment on power delivery but I do recall that running w/out the cross over made the exhaust sound raspier. I also believe that if the cross over is useless, then Mother Harley sure wouldn't go to the expense of using one on all of their bikes.
Here's what I'm after:
1- Eliminate the heat. Well, cams are the real answer to that.
2- Low noise. True duals are a bit louder.
3- Good power delivery. I really don't think that TDs are the best. Certainly not as bad as drag pipes, but not the best.
So, my conclusion is that TDs will make two of my criteria worse and they aren't the best answer to the third. Maybe my reasoning is warped, but that is the tortured mess that whirls around my mind.
Thank you all for your input. Now let's all go RIDE.
