What an evening,,,
Ram, on the first point I'm not sure I agree. In the old V8's, the water running through did not generate heat, it picked it up in a sealed system and therefore even thought bringing heat out of the motor, was typically always cooler or at similar temp to the motor itself.
As for the V-2 being an air cooled motor, it could be shut off with much fear of heat soak. On its re-start it will be cooler. Even though its not moving, or running, its not generating more heat when shut off. The cooling fins promote heat disipation. And since they are emmersed in air, how ever so little movement, its still cooling the engine at a faster rate than a shut off water cooled system.
I've finally added a cylinder fan, and a premium oil cooler to mine, as well as going for Mobil1 in the engine.
I think were on the same page, I also like to take the side streets out of the traffic jams. In my area and the driving I get stuck in its usually on an interstate and the next exit is several miles down the road. And in 2-5 mph that even takes a while to get to.
All good points.
Ok folks, another 2 hour trip home, this time in the RAIN... and traffic...
The motorcycle ran ok to start off, the water was keeping the heat at bay... AIR TEMP staying around 80.. (does this thing really have a use?)
Then the traffic started to SLOW DOWN then Bumper to Bumper..
It held it's own (I think because I was stopping under bridges and shutting her down for a time) but I kept
hearing the HEAT SOAK Thing ringing in my brain, Then I got tired of the wait and decited to push on home.
Went some weird ways (real scary at some points) when I got to the toll road I thought I was Home Free...
about 8 miles up the road DEAD STOP.. move a little STOP Again... THEN THE HEAT MANAGEMENT STARTED IN...
I just came off an 8 mile run IN THE RAIN, and in less than 10 minutes se started getting hot again...
Can anyone say STEAMED OYSTERS... I had to pull over and get out of the sauna...
Next time, I'll just don the rain suit and push thru the usual way home...
It's being dropped off tommorrow afternoon...
I may be ordering a SE CVO.. If they can't get her right...
[IMG]local://upfiles/11910/B019B723909E4B76B6DDA9C0BE6434BB.jpg[/IMG]
[IMG]local://upfiles/11910/2BD632F01F084D99A86552EA854E1BC3.jpg[/IMG]
All problems have ben solved....
Bought a new 07 SG..
No heating problems, or anything....
[IMG]local://upfiles/11910/77353FEC297E48EE9D1D4E901335A347.jpg[/IMG]
Almost everyone that I talked to that had an 06 Ultra had it kick in at least once. Did not seem to matter if it was stock TC88 or a Stage II like mine.
Still looking for solution that does not require the parade fan.
I live in Phoenix also and my '06 RG has only gone into the early stages of H.M. once or twice, 4300 miles, 8 degree injectors. It has never stalled and runs just fine. I don't understand why some are having problems, while others are not. But I wouldn't listen to anyone that says get the bike "tuned." A new bike should be able to run just fine in it's stock configuration and some don't like to modify their bikes, and there's nothing wrong with that. Keep getting in the dealers face, make a stink, make a scene, and contact Milwuakee if necessary.
The only solution is Stage one and SERT. A dyno tune cannot hurt. I agree we should not have to incur this expense but if you want to avoid the designed Heat Management System this is the solution. My SG now purrs like a kitten.
