Help!!!
Old Apr 20, 2010 | 10:24 AM
lks's Avatar
lks
Stage III
Default Help!!!
I have an 07 Ultra Classic. The issue is as follows: Cruise control worked fine, then did not work, now works. Taillights including those on trunk go from bright to dim. Battery is running down. Bike went through a phase where it would die at idle but would start right back up. Any suggestions? Thanks for any replies. Have a great day.
Old Apr 20, 2010 | 10:43 AM
harley-jones's Avatar
harley-jones
It sounds like the charging system is not working correctly. I would start by checking the battery voltage with the bike running. It should be around 14 volts ( check your gauge). These bikes need the proper voltage for all the electroinics to function correctly. You may have a bad battery, stator, ect.
Old Apr 20, 2010 | 11:00 AM
hoethree's Avatar
hoethree
Sounds like a good nuff reason for a new 2010 Ultra!
Old Apr 20, 2010 | 03:33 PM
VETERAN75's Avatar
VETERAN75
I agree jones you should go check your battery and charging sytem. Also check all the wires for tightness.
Old Apr 20, 2010 | 03:43 PM
silverbullitt's Avatar
silverbullitt
That sounds like a grounding problem to me. Those are a bitch to find sometimes too.
tnguyen7607@email.vccs.edu
Jan 25, 2017 12:21 PM
e3tim
Electrical/Lighting/Alarm
Sep 17, 2016 08:45 PM
chasityrick
Sep 1, 2011 11:31 PM
katn0
Jul 31, 2011 07:48 PM
ncpi
May 15, 2007 01:18 AM
