Batwing Brackets
Old Apr 21, 2010 | 05:34 AM
Gofer's Avatar
Gofer
I may have missed it, but I don't see where he has specified it's the (expensive) vertical brackets that run up besides the stereo. If the broken brackets happen to be the horizontal kind that run out to the ends, then buying new HD brackets for $8 each is the better route. The newer brackets have been redesigned (from the 2001 model at least) and appear to be sturdier. If the broken brackets in question are in fact the vertical kind, just buy 2 - 2" galvanized L-brackets and some 10-32 screws. I used the nylon nuts that don't back out. Best and cheapest way (and likely better) way to fix this issue.
Old Apr 24, 2010 | 06:46 AM
KJOGlide's Avatar
KJOGlide
So, has anyone used the Savior250 PSI quick fix kit?
Old Apr 24, 2010 | 06:55 AM
Iceman24's Avatar
Iceman24
I'm w/mrwizard on this one. I've read/heard of this problem on other HD forums & hope to see a recall/tech bulletin to repair the problem. Right now we're just adding $$$ to HD's parts dept. In most cases it seems like the "self-fix" is cheaper & better for now.
hooter57
Audio Systems
Nov 12, 2022 12:24 PM
rysonn
May 17, 2019 09:15 PM
Terrabella
Jul 22, 2011 10:08 PM
maineultraclassic
Jul 11, 2010 09:13 AM
CURTYS06FLHX
Mar 26, 2010 09:26 AM
