2002 FLTR Ignition Switch Trouble
Old Apr 22, 2010 | 06:19 PM
gettin lost's Avatar
gettin lost
6th Gear
Default 2002 FLTR Ignition Switch Trouble
I'm new to Harleys so be kind. I just found a leaking fork seal on my RG and watched the Video and read all the threads on removing the ignition switch.
I follow the video and everything goes great but the switch only moves up about a 1/4 inch. I have pushed down while turning the key as far to the left as it will go and I can't get it to come all the way out. I don't want to force anything because the video makes it look so easy.
Anyone have a suggestion before I call the dealer tomorrow and have them tell me to bring it in.
Thanks
Old Apr 22, 2010 | 07:10 PM
Harleypingman's Avatar
Harleypingman
From the 2002 HD Service Manual:
To remove the ignition switch ****, first turn the Ignition
Switch key to UNLOCK and then turn the **** to
ACCESS. Depress the release button at bottom (left
side) with a small screwdriver, and while pushing key
down, turn 60 degrees in a counter-clockwise direction.
Lift and remove ****.
The video is relevant ONLY if your bike is an '06 or newer model. For older models like your bike, the above quoted procedure does the trick. Do yourself a favor and buy the HD 2002 Touring Service Manual.
Old Apr 23, 2010 | 07:40 AM
gettin lost
6th Gear
Thanks. I have the shop manual ordered just thought looking at the video that I could get started early.
Kermie
Jan 23, 2017 07:15 PM
Recon4
2014-2024 Touring Models
May 30, 2015 12:19 PM
designwebs
Apr 10, 2013 08:40 PM
AK BAGGER
Oct 20, 2010 04:36 AM
adlerx
May 2, 2010 08:56 PM
