pushrod issues....opinions
Old Apr 25, 2010 | 05:13 PM
flhrsi's Avatar
flhrsi
Default pushrod issues....opinions
ok who makes a good quality adjustable pushrod, i'm having issues w/ dealer installed se adjustables, they almost blew my motor[the dealer] had some head work done, had them install the heads[big mistake]I ran it for 4 about 100 mi then brought back for a dyno tune. they started dynoing, had to shut down due to noise,they ended up pulling cam chest & heads to checkfor damage [found none] after they found a loose p-rod. After looking around, I have seen alot of comments about se prods cracking the adjusting nut. Any opinions would be helpful.
Old Apr 25, 2010 | 06:07 PM
kingkingking's Avatar
kingkingking
The only way to guarantee you have no issues is to run perfect fit pushrods (i.e. no adjustment).
In reality there are hundreds of thousands of adjustable pushrods out there, and failures are not that frequent, its likely you were just unlucky, or the builder was clumsy and didnt install them right.
I havent had an issue with my S&S ones, and they are following a 640 cam, but that doesnt mean they are any more failure proof than the SE.
A little loktite and the correct torque is all you can do. Or go perfect fit.
Old Apr 25, 2010 | 11:06 PM
Mike's Avatar
Mike
I keep hearing the new style SE tapered end pushrods are the ones to get. The only question I have, is that since they're chrome moly, aren't they noiser than the older aluminum quick install pushrods?
Old Apr 25, 2010 | 11:23 PM
hog-doc's Avatar
hog-doc
Why would being chro-mo make them noisier? Aluminum rods were pretty popular in Evo motors but not so much in TC's.
The SE tapereds are very nice and they dont rub the tubes. I have installed hundreds of sets of adjustables and NEVER had one come loose. NEVER used (nor would I ever) Loctite.
When you get to your adjustment, hold the tube and the adjuster with the two wrenches and SNUG the lock nut, then set down the 5/16" wrench, hold the tube and tighten the lock nut good and tight, not so tight as to strip it but tight! Ive been doing it this way for years and like I said never had one come loose.
Old Apr 25, 2010 | 11:32 PM
Mike's Avatar
Mike
Doc, if you say they're not any noisier, that's good enough for me. Just something I'd heard, maybe just an old wives tale.
Old Apr 26, 2010 | 09:48 AM
jimski's Avatar
jimski
Any of you know the part# of the SE Tapered pushrods?
Old Apr 26, 2010 | 10:21 AM
hog-doc's Avatar
hog-doc
Originally Posted by jimski
any of you know the part# of the se tapered pushrods?
18404-08
Old Apr 26, 2010 | 10:44 AM
jimski's Avatar
jimski
18404-08
Now that's what I call service!...Thanks, hog-doc.
Old Apr 26, 2010 | 04:51 PM
flhrsi's Avatar
flhrsi
cant go w/ perfect fit, heads are milled, I feel better, sounds like a stupid tech did not know what he was doing, thanks for the help.
NoSecCatfish
Milwaukee Eight (M8)
Apr 20, 2024 03:32 PM
94 ultra
Engine Mechanical Topics
11
Aug 18, 2023 07:16 AM
PeterV
Jul 10, 2018 10:15 PM
skully1200
Exhaust System Topics
Sep 10, 2011 12:13 PM
2wheeltom77
18
Mar 14, 2010 11:43 AM
