Vibrating Standard
Old Apr 30, 2010 | 10:58 AM
mwriggs's Avatar
mwriggs
Compensator sprocket loose???????????????????????Mine was and it made an awful sound as well as extra vibrations.
Old Apr 30, 2010 | 11:23 AM
FastHoss's Avatar
FastHoss
My front motor mount has been oil soaked,cleaned with brake clean and still good at 37,000 but did find that the upper mounts that go into the head were loose!
Old Apr 30, 2010 | 01:02 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Mine wasn't vibrating enough...........................................s o I cammed it till I can no longer use my mirrors sitting still LOL!!!!!! Fixed!!!
Old Apr 30, 2010 | 04:51 PM
Seaweed's Avatar
Seaweed
This is an interesting thread. I have an '05 with about the same mileage and have a pretty bad vibration, too. It's not the fairing. It's much worse than when it was new but the mount looks good. Mine smooths out a little underway but not too much.
Old Apr 30, 2010 | 05:05 PM
Ironbarr's Avatar
Ironbarr
Any possibility it's in the wheels (bearings/spokes), tires (tread/weights), brakes, clutch, etc???
Old Apr 30, 2010 | 07:31 PM
88 Paladin's Avatar
88 Paladin
Found this on an earlier search of this problem : The newer mount is a much harder compound than the early versions, and this new mount will increase the felt vibrations on the bike. The new mounts were beefed up to reduce deterioration from oil contamination, which sometimes occurs during oil changes. If you prefer the softer feel of the early mounts, you can purchase a BUELL motor mount, part number L0501.2, which is the same part as the early touring model mounts. If you use the Buell mount, it installs exactly like your old one, and in the same upright orientation.
SgtDuckyBoy
Aug 12, 2014 02:21 PM
98custom
Jun 17, 2012 10:43 AM
mhutch2
Oct 21, 2008 07:19 PM
electra_gliderider69
May 5, 2008 08:52 PM
Pine Tree
Jan 18, 2008 06:06 PM
