Clutch cable luber question
Old Apr 27, 2010 | 07:07 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by dawg
I've never had luck with those.
Same here.
The one I bought(Lockhart)was to small for the clutch cable.
Now its been hanging on the wall for about 3yrs.
Old Apr 27, 2010 | 08:04 AM
PappyUSMC's Avatar
PappyUSMC
I've never had luck with those. I either use the dri slide with the long needle attachment or use the method attached
Works for me.. gonna give it a try this weekend.
Old Apr 27, 2010 | 09:39 AM
gmc's Avatar
gmc
Originally Posted by hog-doc
I use one daily, no you do not have to disconnect the bottom of the cable but you do have to colapse the cable adjuster And adjust out the ceter screw at the clutch hub just until the cable stops getting longer at the perch end. Open the cable luber all the way and slip it over the housing then all the way over the cable.
Spray just long enough until it starts to spray out at the cable adjuster.
I use this method also since it forces the lube dn the cable. The secret is loosen the center screw at the clutch hub which is a good idea since you are adjusting the clutch also.
If you do every 5k miles and your clutch pull will be much easier.
Old Apr 27, 2010 | 10:48 AM
Leftcoaster's Avatar
Leftcoaster
I've never been able to use my dirtbike cable lube tool on my HD's either so I made one from a piece of clear hose that'll just fit over the loop at the end of the cable. I put a hose clamp around it to seal it at the cable housing and then put a couple ounces of oil in the clear tubing. Then I use my air jet nozzle set at about 5-10 psi and inject the oil down the cable. Only takes one quick squirt of air and it's done.
Old Apr 27, 2010 | 11:18 AM
TheBagger's Avatar
TheBagger
That's a good idea Leftcoaster, I'm going to try it out.
Old Apr 27, 2010 | 12:04 PM
FastHoss's Avatar
FastHoss
I use the needle now alot easier.
Old Apr 27, 2010 | 04:01 PM
Bearcat1's Avatar
Bearcat1
Ok, so with this method the derby cover on the primary has to be open like you're doing a full adjustment so you have access to the center screw. Right now I was just wanting to lube the cable so I'll check this for sure next time I have the cover off and am adjusting the clutch. I think for now I'll see how much I can accomplish with the needle method.
gnalen
Jul 31, 2017 01:31 PM
Weirbt
General Topics/Tech Tips
Apr 27, 2014 07:46 AM
barb6663
Jul 4, 2012 08:09 PM
harley-jones
Oct 1, 2008 06:47 PM
John3:16
Nov 17, 2007 08:41 PM
