Cam question.
Old May 11, 2010 | 09:14 PM
denrock1676's Avatar
denrock1676
4th Gear
Default Cam question.
I have a 06 Road king carbed. SEAC, Bassani Power curve true duals, Bassani 4 in mufflers. Heads ported and polished. SE ignition. Dyno run was 76 hp and 79 fpt. I want to go the next step and get cams. I'm 300 lbs and wife is 200. So I am thinking I really need the low end torque. But don't want it to fall at the higher rpm either. Is there a happy medium? Some one has suggested the SE 211 cams but heard mixed reviews about them.
Old May 11, 2010 | 09:31 PM
ffd796's Avatar
ffd796
If you want to stay with Harley Cams I would go with the SE-203 (more low end) or the SE-204 (great all around cam). I am running the SE-204 now and love the set up, you can see my Dyno sheet in the Dyno Post
Old May 11, 2010 | 09:33 PM
OldPhat's Avatar
OldPhat
211 Cams needs More compression then stock, and a big bore kit would help too.
Old May 11, 2010 | 09:34 PM
PhilM's Avatar
PhilM
Need more info... Is it still an 88, or a 95 / 98 / 103 / etc...???....
What your static compression ratio?
How did you end up with head work & stock cams?
Who did the heads & what was their recommendation?
Old May 11, 2010 | 09:38 PM
Ultra-Tour's Avatar
Ultra-Tour
1st Gear
Stay away from the 211. Had it on my 2005 Ultra and there is NO low end to this cam, it's all high end RMP and the 88 and the 95 have a hard time with it. Lots of engine knock with this cam unless you keep your RPM's high. Even with a DYNO I still had some knocking, even worse when ithe weather is hot. I will never run a 211 again.
Old May 11, 2010 | 09:50 PM
OldPhat's Avatar
OldPhat
Try the 204's
Old May 12, 2010 | 06:26 AM
denrock1676
4th Gear
Oh I'm sorry it is still an 88 in. with 9000 miles. I bought it used from a guy who was getting a divorce. Poor guy. But he wasn't happy about selling it and had a hard time finding out who did the head work. But I was told by the Stealer that it had to have had head work to run 76 hp and 79 fpt. Who else makes good cams? Looked at Andrews cams ( Tw26a).
Old May 12, 2010 | 06:42 AM
smokindave's Avatar
smokindave
Sounds like nobody is sure about head work being done. And why would you do head work with no new cams? You won't know until you pull them and look. I had an 03' RK 95" before and ran the 204 cams, sweet running bike.
Old May 12, 2010 | 09:37 PM
denrock1676
4th Gear
Yeah unfortunatly your right. Well I'm not going to worry about it till the winter months when the riding will slow down or even stop. Thanks for the info and advice.
Old May 13, 2010 | 08:49 AM
jorswift's Avatar
jorswift
I have some SE203's with tensioners and other parts needed for sale in the classifieds. The SE203 and SE204s are very similiar. I have SE203s in my scoot and WOW! Great power for a bolt in cam! Check it out.
Rich67
Oct 27, 2011 07:00 PM
Philly76
Exhaust System Topics
16
Oct 22, 2009 12:59 PM
simpkinst
Feb 12, 2009 02:45 PM
whateva
Feb 21, 2007 12:16 AM
0796tc
Feb 19, 2007 12:45 AM
