Is another clutch spring a good idea?
Old May 12, 2010 | 11:09 PM
1931jamesw's Avatar
1931jamesw
Default Is another clutch spring a good idea?
Is another clutch spring a good idea for a 96" motor with 255 cams? Haven't installed cams yet but I'm hoping for about 85 hp and 100 tq. Would the stouter clutch help or would it be overkill?
Old May 12, 2010 | 11:32 PM
user 8373900's Avatar
user 8373900
I did. The S/E spring gives a very positive engagement. The pull is nearly double the effort but the stock pull was kinda weak to me anyway.
Mark
Old May 12, 2010 | 11:43 PM
1931jamesw's Avatar
1931jamesw
Mark
Do you mean pulling in the clutch lever? Did you try a reduced effort clutch if so, or did your bike already have the reduced effort? I've heard the newer bikes come factory with reduced effort clutch. How much was the SE spring?
Old May 13, 2010 | 12:08 AM
ffd796's Avatar
ffd796
After doing the SE-204 cams I am going to go back and upgrade my spring, and when the 107 goes in the whole clutch is getting changed but that is just me!
Old May 13, 2010 | 12:10 AM
user 8373900
The spring was around 50 bucks. Yes my 07 had the reduced effort clutch. It was pretty weak when really hot. You can definitely tell there is a stronger spring when you pull the lever now.
Old May 13, 2010 | 06:17 AM
mainshaft's Avatar
mainshaft
See below my pic, that is how my bike is set up. I'm pulling 89HP and 99TQ with no clutch issues, my 2 cents.
Old May 13, 2010 | 08:50 AM
gwcrim's Avatar
gwcrim
If it ain't broke, don't fix it.
Ride the bike a bit and if the clutch slips, upgrade. Some folks are harder on parts than others.
My daddy always said, I could break an anvil. He was pretty much right.
Old May 13, 2010 | 08:55 AM
1931jamesw's Avatar
1931jamesw
Good point. My pops always told me I could tear up a steel ball.
Old May 13, 2010 | 09:28 AM
Leftcoaster's Avatar
Leftcoaster
See if it slips (and it probably will) then add the SE spring. The lever pull is stiffer but far from obnoxious. Some evidently have been able to install the spring through the derby cover but mine wouldn't without distorting the spring. Still a minimal job even r&r-ing the outer primary, and no more slip.
Old May 13, 2010 | 09:33 AM
Donnylee's Avatar
Donnylee
I put an SE spring in mine. It cheap and easy upgrade. I recall it was under $30 to do it.
Firemn17
General Topics/Tech Tips
Jul 21, 2016 12:25 PM
ridedaddy
Jan 2, 2015 07:05 PM
slyedog
Jul 28, 2014 10:31 PM
Iron lHorse
Nov 17, 2013 10:31 PM
Born2cure
Nov 21, 2009 08:37 AM
