2010 SG Front End Dives When Braking
It lowers the bike to help keep the stock stance after you install the 21" and it will help with your diving as well.
Differences not including the top out springs which you re-use the same.
There you have it as this is the stuff they do not tell you about until you have already spent your money.
If you look closely you will see holes. Back in the day when racing and no aftermarket suspension was available to buy, we would weld up the holes, turn the welds round, than drill different size holes (larger will allow more fluid to pass and smaller will allow less).
When heavier oil is used, stiction is created. Put a shaft into 2 oils (heavier and lighter). Watch how slowly the heavier oil comes off the shaft than try wiping it off of the shaft with your fingers. Than do the same with a light oil. That resistance is called stiction in suspension speak.
The (intended) lighter the oil the easier/properly the suspension works, add/replace heavier oil the harder it is to move the suspension therefor you can guess the rest (harder ride). You can slow the rate of travel/time by adjusting the flow of the light weight oil through various means starting by what you already have. There you have it, think prior to doing.
Ohlins suspension theory is to only use the correct resistance springs to overcome gravity and set the piston in the proper position inside of the body (in this case fork tube). The actual suspension does all of the work and not the springs. Again: Just overcome gravity and not be a spring on a stick.
Experiment and do for yourself, much more rewarding when it works out for you. Remember the air spring!
Nice post, very accurate explanation. I am not knocking those who are happy with stiffening up their front suspension by using heavier fork oil. As you said, it just does not make good suspension sense to minimize both compression and rebound to minimize an excessive front end dive issue. Yes it will do it, but at the expensive of greatly limiting rebound. Perhaps those who only ride on relatively smooth roads, or dont push their bikes very hard can get away with it. For most it will create a bone jarring experience with increased road inputs being felt in the front.
Ohlin suspension theory is actually very good suspension theory and has been around for a long time. Use the springs to hold your ride up,( bike, auto, truck, racing vehicle.. whatever) or as you say gravity and let the suspension components handle the road inputs, and do not restrict those components with heavy fork fluid.
Great pics with a great write up. Again for those that heavier fluid has worked for and you are happy with your results thats great, but not something that any real suspension guru would recommend doing.
