Old Mar 17, 2015, 05:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Having issues with your audio equipment? The first post gives great tips on self-diagnostics in order to help pinpoint your issue. Forum members list their issue and solutions that worked for them.
Read the full discussion below to find out if your issue is listed and what helped forum members fix the problem.
Print Wikipost
Self-Diagnostics for Harman Kardon radios
Old Jan 4, 2013 | 06:45 AM
  #151
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
Originally Posted by garybsac
I have a '09 Street Glide, an after market amp,and the dreaded B2017 (everything works but no sounds). I solved my problem by turning the ignition to accesory with the radio off....wait a minute....turn on radio...play for a minute & turn off. Then start bike and turn on radio. Everything works great. So far so good. I guess it gives the radio time to recognize the amp?
The B2017 code will always be present with an aftermarket amp in the system whether there is a defect with the radio or not. The radio sees the impedance from the amp as a speaker error.
Old Jan 5, 2013 | 08:26 AM
  #152
marvincbr's Avatar
marvincbr
Originally Posted by Iron Cross Audio
Could be an amp, but usually only part of the issue if at all. If vibration damage exists on the board, replacing the amp will mask it temporarily by heating the affected traces. It will eventually resurface. This is why you're radio is now working again. Removing / reinstalling the unit will flex the board enough to allow the traces to contact resulting in the reappearance of the audio. The installation of an anti-vibration mod is also key to prevent the re-occurrence. The factory...and by extension the refurb facility..has made attempts at stabilizing the board, but in our opinion, do not go far enough. Our vib mod has had significantly more success.
Good luck.
Is this vibe mod part of your "updates and modification" package?
Old Jan 6, 2013 | 04:49 AM
  #153
Iron Cross Audio
Former Sponsor
Yes it is
Old Feb 7, 2013 | 02:39 PM
  #154
tigerrick's Avatar
tigerrick
Stage II
Default radio
Originally Posted by ohiohusky
My HK diagnostic says B2018 fl speaker open. No sound from any speakers. Please advise, as I am new to this and have no idea of what to do. Thanks in advance. 2006 Ultra Classic.
hi i have an 06 ultra screamin eagle with the same problem no speakers play came up with code b2017
Old Feb 8, 2013 | 08:06 AM
  #155
Iron Cross Audio
Former Sponsor
That bike would have an external amp, so the issue could be either the amp or head unit.
Give us a call and we'll try to walk you through a couple of things.
Old Feb 10, 2013 | 09:52 PM
  #156
Lundee's Avatar
Lundee
Howdy, My dad's bike (2008 flhx) has the b2017 code. It worked two days ago, then we put new bars internally wired on & tah dah the speakers don't work. My question is this: Would this code show if a wire in the handle bars was shorting or pinched? All the switches on the hand controls work fine. Also the right vertical bracket was broken. Thanks in advance, I feel like crap because I told him the bars swap was easy & now this.
Old Feb 11, 2013 | 05:06 AM
  #157
Iron Cross Audio
Former Sponsor
No, there is nothing in the bar controls that would trigger this code.
Old Feb 13, 2013 | 02:21 PM
  #158
Lundee's Avatar
Lundee
Thanks ICA. Dealer wouldn't let him just bring the stereo down. Had to ride it down, so they could take it apart, say it's jacked, order a new one 2-3 weeks, put it together. I wonder why a new bike cost 30k. It's under warranty though. Thanks again.
Old Feb 18, 2013 | 10:22 AM
  #159
caltrain's Avatar
caltrain
Having issues with the sound after starting....sometimes there is no audio. I have to shut off the bike and restart several times for it to work. I have an external amp on my 2010 flhx and was wondering if this is a amp or head unit issue? Sound works prior to starting and this issue occurs about 20% of the time.
Old Feb 18, 2013 | 09:22 PM
  #160
rtuuji's Avatar
rtuuji
I realize I am brand new here and already begging for help but it would be greatly appreciated. My 06 Ultra HK radio is displaying error code B2006 after I do the diao check on it. The volume adjust works just fine but when I push in the Audio button in I cant get my bass, treb, fade......settings to display. Does anyone have any idea what I can try to fix the problem?
