Old Mar 17, 2015, 05:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Having issues with your audio equipment? The first post gives great tips on self-diagnostics in order to help pinpoint your issue. Forum members list their issue and solutions that worked for them.
Read the full discussion below to find out if your issue is listed and what helped forum members fix the problem.
Print Wikipost
Self-Diagnostics for Harman Kardon radios
Old Jan 16, 2011 | 11:45 AM
  #51
hdflhxi06's Avatar
hdflhxi06
1st Gear
Question Help Please
I have lost my display on my HK Stereo. Other than that it works fine.. lol.. Hate to pay $250.00 and send it in for repair.
Old Feb 2, 2011 | 09:43 PM
  #52
cihjr1408's Avatar
cihjr1408
Default Please help
Hello all, I realize I am brand new here and already begging for help but it would be greatly appreciated. My 06 Ultra HK radio is displaying error code B2006 after I do the diao check on it. The volume adjust works just fine but when I push in the Audio button in I cant get my bass, treb, fade......settings to display. Does anyone have any idea what I can try to fix the problem?
Old Feb 2, 2011 | 10:20 PM
  #53
Harleypingman's Avatar
Harleypingman
I'm not a tech, but there seem to be very few issues with the HK system that can be fixed w/o replacing parts. If your bike has seen a fair amount of use, I'd suspect the switch is bad which seems to be what your code is saying. You should also check-out the wires exiting the switch housing for a pinched wire. If you have the service manual, you can identify the wire colors for the audio switch--the insulation is very thin and easily cut to create a short from the wire to the housing.
Carl
Old Feb 3, 2011 | 08:14 PM
  #54
the bad bagger's Avatar
the bad bagger
I have a 2006 Road Glide the display comes on with a radio station no sound. None of the switches or buttons work I cannot eject the cd. Can this be repaired or should I throw it in the trash.
Old Feb 18, 2011 | 08:20 AM
  #55
shortride's Avatar
shortride
I have not been able to diagnose an issue with the radio on my '09 Ultra Classic. As far as I can see, it is not covered in this thread.
After the Ultra Classic sits for various length of time. Sometimes only after one day, the radio defaults to channel 1 when the ignition is turned on. The preset buttons are still set when this happens and channel 1 is not one of the preset channels.
It's one of those issues that the dealer can not reproduce.
Old Feb 20, 2011 | 06:39 PM
  #56
pridesawsupply@comcast.net's Avatar
Stage IV
I'm having a problem with my Intercom on my 2007 Electra Glide UC. The drivers mic does not work, passenger's mic works and when I switch helmets the drivers mic works on the passengers plug in. Anyone have any answers?
Old Feb 21, 2011 | 05:25 AM
  #57
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
There are alot of variables between harnesses and the radio. Best bet would be to contact Iron Cross Audio and have them walk you through it
Old Mar 15, 2011 | 09:20 PM
  #58
2006 Ultra's Avatar
2006 Ultra
Stage IV
Where can I find the down loadable update software that is mentioned? URL???
Old Mar 16, 2011 | 08:34 AM
  #59
prostar's Avatar
prostar
http://www.harley-davidson.com/en_US...bmLocale=en_US
The file needs to be copied on a CD to use in your radio. Dont use a DVD
Old Mar 17, 2011 | 04:59 AM
  #60
stealthgoat's Avatar
stealthgoat
Thanks for the link.
