Old Mar 17, 2015, 05:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Having issues with your audio equipment? The first post gives great tips on self-diagnostics in order to help pinpoint your issue. Forum members list their issue and solutions that worked for them.
Read the full discussion below to find out if your issue is listed and what helped forum members fix the problem.
Print Wikipost
Self-Diagnostics for Harman Kardon radios
Old May 21, 2011 | 12:33 AM
  #71
Harleypingman's Avatar
Harleypingman
Originally Posted by Navy Mustang
The fairing vibration is BS. . . . I mean, c'mon, What more can be done to isloate the radio unit from the vibration of the bike?
The vertical fairing brackets were notorious for breaking, which increased the vibration in the HK radios. HD has redesigned the vertical brackets to make them less susceptible to breakage.
Also, the bottom of the HK radio was hitting the riser bolts increasing vibration in the HK radio. HD introduced a new bolt with a shorter head to avoid contact with the radio.
Also, since its introduction in the 2006 model year, the HK has undergone changes to strengthen soldered points to make them less susceptible to breakage from vibration among other changes.
You're right; these bikes vibrate. But HD has taken steps to reduce vibration transmitted to the HK radio, and the radio itself has been changed internally to make it less susceptible to vibration damage.
Carl
Old May 24, 2011 | 06:17 AM
  #72
shortride's Avatar
shortride
What does it mean when you do the diagnosis and the issue with the radio doesn't show up? Does that mean the problem isn't with the radio for sure?
Old May 25, 2011 | 05:05 AM
  #73
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
It means the defect is presenting itself electronically in a way the diagnostics cannot decipher. Cant say if the defect is in the radio or not, depends on the defect.
Old Jun 22, 2011 | 10:48 AM
  #74
Timholdy's Avatar
Timholdy
4th Gear
Default Help?
Did the start up sequence, no hd logo but d1 shows on display, i am confused?
Old Jul 16, 2011 | 04:54 AM
  #75
frank flhxi's Avatar
frank flhxi
Stage IV
very useful information.Thank you.
Old Jul 27, 2011 | 11:24 AM
  #76
Twicebit's Avatar
Twicebit
3rd Gear
Have 07 FLHTC with stereo problems. Everything shows on and working but speakers only working intermitantly. Have updated the software and done diagnostic check. Shows SpkA. Is this a switch problem or speaker problem?
Old Aug 7, 2011 | 09:05 PM
  #77
1320str8_liner's Avatar
1320str8_liner
I have an 09 Streetglide and my problem is, I have changes the speakers to 6.5's and added a Arc Audio amp, and now it plays for a bit them cuts off, radio stays on music just shuts off, if i turn the radio off/on the music will play again for a few min. When I cycle the radio off/on it's only the radio turning off the amp is wired to ignition switch w/ lights. Hummm help?
Old Aug 7, 2011 | 09:25 PM
  #78
Stang951's Avatar
Stang951
Sounds to me like the amp maybe cutting out. Possibly overheating or maybe not receiving enough power. I had a PUNCH amp that used to do that because it would overheat. Had some kind of problem internally and worked fine once I had it repaired.
Old Sep 6, 2011 | 11:12 AM
  #79
TallTexan's Avatar
TallTexan
Thanks for the post. I've been swapping out speakers, OEMS and J&M sound fuzzy. I may have a short or radio issue, guess I need to check the codes.
Old Sep 10, 2011 | 06:56 PM
  #80
Stoood's Avatar
Stoood
Default Display Failure on '08 FLHTCU Harman Kardon
Last week, I was bugging my trike's tour pack stop lights for an unrelated problem (using a VOM). I don't know if this is related, but the next time I was riding, I noticed that my display was bright red with NO characters displayed whatsoever. The unit works fine, as I remember how to operate each mode without looking at the display. Is there any way to troubleshoot the LCD display failure, other than send the entire unit into my Harley Dealership? I'm a retiired EE, but there's little I can do without having a functional schematic or knowing the SW scheme of the unit. I have been wanting to add SiriusXM, perhaps now would be a good time to switch to a new Sony head (an expensive venture, but with the $40K+ I already have invested in my trike, why not)? Any suggestions on upgrading to a new head? -Thanks in advance!
