Old Mar 17, 2015, 05:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Having issues with your audio equipment? The first post gives great tips on self-diagnostics in order to help pinpoint your issue. Forum members list their issue and solutions that worked for them.
Read the full discussion below to find out if your issue is listed and what helped forum members fix the problem.
Print Wikipost
Self-Diagnostics for Harman Kardon radios
Old Mar 19, 2011 | 07:27 PM
  #61
Linville Lion's Avatar
Linville Lion
I have a 2011 EGC with Zumo 665 and NIM. Finally got it all to work together, except....if I am listening through the AUX and change to AM/FM/WB, occasionally the AUX will override the AM/FM/WB. Makes no sense that the Aux should override the other channels.
I also have a B2021 error...I suspect that is because I have the headset/intercom harness installed without the rear speakers...do not have rear speakers.
Old Mar 31, 2011 | 01:51 PM
  #62
rocknrod's Avatar
rocknrod
I burned the CD as the instructions said. Checked the CD for the files - Okay.
Hit the soft keys, turned ignition switch to Access, pushed the update button, inserted the CD.
It said it was updating it (...verifying DSP image). Sat there for about 30 minutes running, no change.
Radio didn't turn off/on as the instructions said it would.
Turned it off, turned it on ejected the CD.
Everything works fine.
Check to see if the software was updated - Not Done, still has the old software.
Everything still works fine however.
Old Apr 2, 2011 | 08:51 PM
  #63
mu321's Avatar
mu321
6th Gear
Default Rockford Fosgate
I got a set of Rockford Fosgate P1S652 4 ohm speakers that I want to install on my '09 FLHX with the stock radio. My question is, will this work? I heard that you either have to use 2 or 8 ohm with a stock stereo but then I was also told that I can install these because the stock radio has a amp already built in. Which is correct?
Thanks,
Ryan
Old Apr 7, 2011 | 11:36 AM
  #64
bad2dabone's Avatar
bad2dabone
thanx for all the info.....
Old Apr 7, 2011 | 12:28 PM
  #65
tpgun10's Avatar
tpgun10
Thanks-good info./posts. I am sending my B2017 Code prob on my unit from a 2007 SG to Iron Cross Audio for repair now. Tony there is a good help and expleins things etc. Looks like mine has a bad audio board from too much fairing vibration. No sound/volume at all...everything else works. SUCKS!
Old Apr 24, 2011 | 07:38 PM
  #66
fannin's Avatar
fannin
Mine's showing B2018 Says Front Left Shorted to Ground. I replaced it with new hog tunes, and checked the ground. Could it be the head unit? Or am I missing something?
Old Apr 25, 2011 | 05:58 AM
  #67
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
It's most likely the head unit
Old May 17, 2011 | 03:33 AM
  #68
White Knight 04's Avatar
White Knight 04
Wow thanks for the info it really helps....
Old May 20, 2011 | 10:07 AM
  #69
Navy Mustang's Avatar
Navy Mustang
The fairing vibration is BS. I mean, c'mon, we all know these bikes vibrate. When I sent my radio into Iron Cross for repairs (great job they did by the way) there was a little sticker on my radio telling me to ensure everything's installed tightly as excessive vibration was probbably the cause of the initial failure to begin with. Crazy. These are Harleys, they vibrate. What more can be done to isloate the radio unit from the vibration of the bike?
Old May 20, 2011 | 10:58 AM
  #70
gunnyBob's Avatar
gunnyBob
Thank you, may help one day...
