HD forums to the rescue again!
Old Jun 20, 2010 | 05:42 PM
rg_dave's Avatar
rg_dave
Default HD forums to the rescue again!
I rode my bike this morning then came home to change the oil in all three holes. I am fairly experienced working on bikes and use a torque wrench so I don't over tighten things. I went to tighten the primary drain, set the torque wrench to 14 lbs (low end of 14-21 ft-lbs in the manual) and hand tightened the plug. When I went to tighten it with the wrench it just spun. I backed it out and the threads came with it. I have a trip coming up and no shops were open so panic was setting in. I got on here and did a search and found a tip about a 12-20, 1 over self tapping drain plug. Picked one up at the auto parts. It worked like a charm! Saved my bacon again. Thanks HD forums!
Old Jun 20, 2010 | 05:59 PM
Jags93's Avatar
Jags93
Yeah, this forum provides an incredible depth of information and expertise.
plus, you get to talk plain old bike sometimes.
Old Jun 21, 2010 | 02:26 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Has saved me countless hours, $$$'s, hedaches.
Old Jun 21, 2010 | 04:48 AM
Notgrownup's Avatar
Notgrownup
I can't count the times i have used wisdom from here...Saved me a boatload of money and time.
Old Jun 21, 2010 | 05:53 AM
smokindave's Avatar
smokindave
This forum has saved me money and cost me money. I wouldn't want it any other way.
Old Jun 21, 2010 | 07:01 AM
2WheelGlider's Avatar
2WheelGlider
Have to agree, I think this forum cost me as much money as it saves me. Actually, it does save me money on the things I discover that I just have to have!
Love It! Thanks to all those that put up the valuable information.
Old Jun 21, 2010 | 07:11 AM
Ridewva's Avatar
Ridewva
LOL, that's the truth!
Old Jun 21, 2010 | 07:43 AM
dirtracin23's Avatar
dirtracin23
The forum is a wealth of information both useful and useless.
Just a comment on your use of a self tapping plug. It is only going to serve as a temporary fix. Every time you remove and then re-install the plug it is going to try again cut "new" threads. So after a few times you will have to go up to next larger size which would be a double oversized. Although it will serve your needs just fine for now, I would keep my eyes open for a slighty used (or new) primary cover. Just be resolved to the fact that, sooner or later, you will have to come up with a more permanent solution.
Rickr01
Oct 10, 2014 08:38 PM
noserider
Nov 4, 2011 06:53 PM
Navy UC Rider
Jun 18, 2010 07:27 PM
spizzyman
Aug 15, 2008 11:26 AM
Electraman
May 18, 2007 09:13 PM
