Lowering Questions
Old Aug 29, 2006 | 02:52 PM
tduff's Avatar
tduff
Default Lowering Questions
I want to lower my '06 FLHTI, but wanted to know the best way to go. The stealer says that they can install a block that moves the bottom of the shock rearward or install shortened airshocks. I want to lower the seat height 1"-1.5" and am seeking the advice of others that have done it.
Who makes or sells the best lowering kit? Should I lower the front also? How much will it change the way my bike handles?
Thanks,
Troy
Old Aug 29, 2006 | 03:19 PM
77Tulsa's Avatar
77Tulsa
Default RE: Lowering Questions
I did both and then lowered the front with the progressive lowering kit. Some say the blocks cause binding in the shocks. I haven't noticed it. Mine is lowered 2 1/2" in the back and 2" in the front. I used the White brothers kit on the back. My bike has a different front suspension than yours so I don't know if you could lower it in the front 2".
Old Aug 29, 2006 | 03:26 PM
bountyhunter's Avatar
bountyhunter
Lower the front/rear 1" with HD Profile gear. The Sundowner is a 2-up that will get ya lower as well!
Old Aug 29, 2006 | 04:02 PM
DI75's Avatar
DI75
I did the so -lo and every bump I hit just about killed me. I took it off 2 days later. It is yours for 50.00 plus shipping but dont say I didnt warn you !!
Old Aug 29, 2006 | 06:25 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
Lower both the front and back equally ... just the back effects handling.
Old Aug 29, 2006 | 06:34 PM
cutacroshorty's Avatar
cutacroshorty
What's the cost of the HD lowering gear?
Old Aug 29, 2006 | 08:09 PM
Bagger97's Avatar
Bagger97
The lowering block works fine, Burly has one that lowers 1.5 inch and Arlen ness has an adjustable block 1-2 inch. Do it yourself and save a bunch, only two bolts (if you have a bike lift).
Old Aug 29, 2006 | 08:14 PM
dchoran's Avatar
dchoran
R.U.B. kit = 2 1/2" but needs 35psi.
Old Aug 29, 2006 | 09:37 PM
RonH's Avatar
RonH
I'm running the TRW 1.5 inch brackets on the rear of my EG and 20lbs of air is perfect for me solo. Didn't lower the front and love the handling and feel.
Old Aug 30, 2006 | 02:02 AM
speeder75's Avatar
speeder75
I have a wierd question.
Why does the Harley stuff lower 1 inch in front and only 3/4 in the back ??? Seems backwards to me ???
