Inner Primary removal
Old Jul 30, 2010 | 06:59 AM
spiker's Avatar
spiker
Default Inner Primary removal
Was going to remove my inner primary,the shop manual says to use the inner primary race tool to get the race off.Is the tool really required?The price on one is $304.If that's the case I'll just take it to the dealer,since I'll probably never use the tool again.Thanks
Old Jul 30, 2010 | 07:02 AM
dog155's Avatar
dog155
You have an older machine! Without that tool you will not get the race off.That same tool will be needed if you want to reinstall the race.A solution is the Shovelhead bearing and seal conversion.Once converted you will never need that tool again.
Old Jul 30, 2010 | 07:05 AM
spiker's Avatar
spiker
It's a 02 EGC,58,000 miles.I guess it needs the tool.-Thanks
Old Jul 30, 2010 | 07:18 AM
dog155's Avatar
dog155
Gary,see if you could rent the tool or see if the dealer would work with you.Either way convert your primary to the Shovelhead version it is a boltin and permanent fix.Zippers sells the kit.Good Luck Dog
Old Jul 30, 2010 | 07:57 AM
jamesw's Avatar
jamesw
Are you sure you need to remove the race just to remove the inner? I don't think that's so, but I could be wrong.
Unless of course you are planning on replacing the bearing and inner race while you are in there.
In any case, try here for 1/3 the cost.
Tool Number 620060
http://www.georges-garage.com/trans_pre_o7.htm
Old Jul 30, 2010 | 05:15 PM
harry.b's Avatar
harry.b
you don't have to remove the race to remove the inner primary. You have to remove the compensator and clutch pack and chain. You just pull them off as an assembly. The primary will slip right off after you remove the bolts that hold it to the case and transmission. It looks to me that that you only need to remove the race if your replacing it or getting into the transmission. I didn't have to remove the race.
Old Jul 31, 2010 | 04:12 PM
Egldr05's Avatar
Egldr05
You don't need to remove the race to remove the inner primary. If you did need to remove it all you have to do is carefully cut through it most of the way with a Dremel tool and cutoff wheel (being careful not to cut into the shaft) give it a few light pops with a chisel and it falls off.
Rick
miketv84
Jul 9, 2019 01:39 PM
kylebryan
Jun 14, 2015 06:38 PM
bigheadted
May 5, 2015 10:53 AM
jmn1960
Feb 11, 2014 07:48 PM
speakerfritz
Aug 7, 2011 12:34 PM
