2010 FLHR Road King
Old Jul 31, 2010 | 12:09 PM
tstammer's Avatar
tstammer
Default 2010 FLHR Road King
Just took delivery of the 2010 Road King, I need to raise the handle bars until I can install new bars, how do you get to bar clamps with the handle bar lock on top of the clamps?
Old Jul 31, 2010 | 02:29 PM
dawg's Avatar
dawg
Old Jul 31, 2010 | 02:31 PM
dawg's Avatar
dawg
Section 2.22 on page 2-71 of the 2010 touring manual will explain removal and installation. A manual, pn# 99483-10 is a must at $60 retail
Old Jul 31, 2010 | 02:37 PM
shadowrunner's Avatar
shadowrunner
Not sure on a 2010 model, but my 07 RKC you need to remove the headlight nacelle to remove the cover,
take off the windshield, headlight chrome ring, then unscrew headlight and unplug and sit aside.
Inside on top remove nut holding top nacelle chrome strip on, then on fork lock, pry off
plastic cover plate and remove two screws, then reach back inside nacelle and loosen
screw and nut at the front of the clamp cover. Remove acorn nuts on left and right side
of the forks, cover fender to protect, remove passing lamps and bracket and sit on fender
remove grommets and clutch cable mount. Slightly separate nacelle slide out clamp cover,
reach inside nacelle disconnect aux. switches, remove nacelle.
Loosen rear screws on upper bar clamps, re-position bars, make sure bars are centered, snug
upper handlebar clamp screws, check full lock position for clearance on both sides, then
torque upper handlebar clamp screws to 16-20ft lbs.
Re-install nacelle and connect switches, install clamp cover tighten all three screws on it to
10-20inch lbs., install top chrome strip tighten 10-20inch lbs. install grommets, light bracket,
clutch cable holder, and tighten 72-108inch lbs. install headlight and tighten 9-18inch lbs.
install chrome ring and tighten 9-18inch lbs., install windshield.
Old Jul 31, 2010 | 02:43 PM
dawg's Avatar
dawg
That's correct, the pic posted above is just for tightening the screws. That's why I suggested a manual.
Old Jul 31, 2010 | 03:46 PM
carpetride's Avatar
carpetride
Or you could just yank like hell on the SOBs till they are where you want them.
Old Jul 31, 2010 | 04:05 PM
tstammer's Avatar
tstammer
Dawg,
Thanks for the infomation, I went out and bought the manual made the changes worked out fine. I could of saved $60 if I would of waited for your post.
Just kiddingThanks for the help.
Old Jul 31, 2010 | 04:17 PM
883 IRON's Avatar
883 IRON
Could of, but IMHO having a service manual is a good read and the best way to find out as much as you can about your Harley, best 60 I ever spent
burnit2012's Avatar
burnit2012
Your gonna need that manual. Congrads on th FL.
Old Aug 1, 2010 | 05:55 PM
TooEasy's Avatar
TooEasy
+1 on the manual, and establish a good rapport with your dealer, lol. Otherwise they can be kinda hard to work with.
Regards,
Chrome Sweet Chrome
Apr 7, 2018 03:14 PM
sealbeachbum
Oct 3, 2012 11:58 PM
Petesnot
May 23, 2009 07:11 AM
Reddawg
Jan 4, 2006 02:57 PM
Col Fod
Jan 27, 2005 11:42 PM
