Do you know what EITMS is?
Old Aug 3, 2010 | 02:28 PM
  #31
frenchbiker's Avatar
frenchbiker
Originally Posted by 44492001
Your bike must be at idle with the engine oil temp above 262 degrees for EITMS to kick in. It's dealer enabled during initial bike set up on 09 and later.
Oil temp is not what makes EITMS kick-in. There's no oil temp sensor on our bikes.
The front cylinder head temp is what is used by the EITMS and there's a sensor in the front jug.
Old Aug 3, 2010 | 02:31 PM
  #32
santajim's Avatar
santajim
I just had to go out and see if mine worked. Turn ignition on shut off switch on roll throttle off hold for a few seconds and presto it flashed cruise light first to red did it again and flashed green.
This place is awesome.
Old Aug 3, 2010 | 02:49 PM
  #33
Heatwave's Avatar
Heatwave
Member
Originally Posted by ehans
I am sure with the right computer setup you could make changes to it, but at some point the engine needs to operate in a certain range.
In all honesty, I cannot tell the difference at stop lights. The rumble changes, the odor shows up but I don't feel a cool breeze between my legs. You are sitting there in 90 degree weather on 110 degree asphalt with 100% humidity and a 280 degree motor between your legs. Would it matter if it was 262, 250 or 200?
Mid-frame air deflectors make more of a difference IMHO.
I agree. The rider really gets no benefit from EITMS. Essentially it helps to keep from "breaking down" your oil while sitting at a light after the engine is hot on a hot humid day. As the oil circulates throughout the engine, there is a cooling effect as the oil nears the rear cylinder at least as compared to the front cyl. The result is a cooling effect on the overall temp of the engine.
No real benefit to the rider although I guess you could make an argument that the heat from a 280 engine feels more uncomfortable than an engine at 260 degrees. EITMS is a good thing from both an engine and oil longevity pov.
Old Aug 3, 2010 | 04:14 PM
  #34
lh4x4's Avatar
lh4x4
It cuts the injector to the rear cylinder 100%. If it did not the fuel would burn up the converter real fast. If you want to see a hot Harley that would be one.
I makes the rear cylinder simply an air pump which will cool the rear cylinder down.
This system was first introduced in the 06 Street Bob. It is described in the owners manual.
In my 2010 Ultra Classic owners manual it states that it cuts the rear fuel injector off when the rear head reaches 385 degrees. That would strongly suggest that the front cylinder and the oil temp has nothing to do with the activation. It is the rear cylinder that runs hotter than the front so it would only be logical to place the sensor there.
Old Apr 8, 2011 | 07:00 AM
  #35
R_W_B's Avatar
R_W_B
This was an interesting old thread. I've also read that there is a consensus that this mode was created primarily for rider comfort (eliminating hot thighs) from heat coming off the rear cylinder.
The front cylinder is still going to be running pretty hot since it's cooling fins are not connected to the rear cyclinder. The only thing I would use this mode for would be a signal it's time to turn my engine off (or get moving).
Old Apr 8, 2011 | 07:28 AM
  #36
geezer glide 56's Avatar
geezer glide 56
Has nothing to do with oil temp...Based on engine temp...On touring models the owner can enable and disable...Not all dealers enable at initial set up.
Old Apr 9, 2011 | 01:54 PM
  #37
ehans's Avatar
ehans
Technically, the cylinder head temp of the front jug.
And on softails, they have to enable it at the dealer with their computer, or disable. I recommend enabling it. I turned mine on when I got both bikes pictured and have never disabled it.
Old Apr 9, 2011 | 02:10 PM
  #38
ehans's Avatar
ehans
You can see it work at http://www.harley-davidson.com/en_US...html#/features - select Comfort, then EITMS. One still shot and one small video. THey used to have a video that claimed the rear cyl would pump cool (outside air) temp through the system and bring down the exhaust temp of the front cyl, but I cannot find that anymore.
Heck, looks like they added it to the 2011 Dyna line too.
Old Apr 9, 2011 | 04:08 PM
  #39
R_W_B's Avatar
R_W_B
Post
I have heat mode capability on my 2007 Dyna. I don't have it enabled though.
Yes I've seen that web link, it mostly talks about lowering rear cyl temp for rider comfort. As you said the other video is not longer there but for the llife of me I can't see how that is going to cool the front cyl or the front exhaust. Even if the oil is cooled by the rear cyl shut down, in the Twin Cam the oil is not circulated in the heads where all the heat is. At best it's splashed up inside the piston to the cyl walls and I believe the TC still has a wrist pin oil spurt. I don't have a problem with the Heat Management. I just don't think I would really want to run my engine once it kicks it. This is all interesting read though.
I run a lenale fan to deal with heat so I don't sweat all this really. There is a test done by a guy (on this fourm) where the lenale fan kept his bike out of heat mode. It blows air on the heads where the heat is.
Old Apr 9, 2011 | 04:26 PM
  #40
USMC2010's Avatar
USMC2010
My 2010 Wide Glide has it but it had to be turned on by the dealer. I cannot activate it by throttle roll, and yup it turns on in the desert often during the summer.
