iPod interface
Old Nov 27, 2012 | 06:45 PM
  #221
davessworks's Avatar
davessworks
Originally Posted by pjb
Go to Iron Cross Audio and get it for $250 with free shipping.
Suddenly a bigger difference.
Taht's cool. As long as it works for you go for it.
Old Nov 27, 2012 | 07:35 PM
  #222
skratch's Avatar
skratch
Originally Posted by gpp
so does avc work with either one of the interface kits or not?
i have the hd version, it works on my bike.
Old Dec 3, 2012 | 08:54 PM
  #223
2006gliderider's Avatar
2006gliderider
Look up Iron Cross.com They have the same ipod interface for a fraction of the price, and riders claw makes a bar mount for your ipod. Hope this helps you out.
Old Dec 4, 2012 | 01:38 AM
  #224
emwolb's Avatar
emwolb
ironacesspeedshop sells a cable set for our bikes which use the harmon kardon stereo. the wiring harness plugs into your ipod and charges it while your bike is running. there is also the 1/8" round plug for the audio. the audio cable has a 90 degree bend molded into it where it plugs into your radio. the charging cable plugs into the accessory plug which is under the seat of our touring bikes. i think the loom is 52" long which is plenty if you choose to keep your ipod in your saddlebag or tour pack. ironacesspeedshop.com and it's $60 bucks, with free shipping. they're in north carolina, and mine should be in wednesday. i only keep music that i really like to listen to, so as long as it charges my ipod and plugs in to the audio port on the stereo, i'm good to go. i'm thinking that the chrome tank panel would be the easiest route for the wires rather than removing the tank. look at their site and you'll see the ipod cable set. it looks to be of great quality, and you don't have to remove the outer fairing to install.
Old Feb 3, 2013 | 01:20 PM
  #225
bklyn roadking's Avatar
bklyn roadking
o here is my problem i have a 2011 RGU and have the ipod interface that im installing.the 35 pin connector is in the bike there is wires in all the pin hole except for 5 of them.now here is the thing in the connector there is 5 white pin do i remove those and install the 5 wires from the ipod interface harness because my 35 pin connector has no numbers on them and dont know how to count the connector left to right etc also its 3 rows.
Old Feb 3, 2013 | 02:57 PM
  #226
MontyCop05's Avatar
MontyCop05
Yes. You remove the seal pins from the slots you need to insert the wires from the interface. The 35 pin connector is marked on the back to show the numbered pin locations. Top row from left to right is 1-12. 2nd row fri left to right is 13-23, 3rd row from left to right is 24-35.
Old Feb 7, 2013 | 09:22 AM
  #227
AbnMP13's Avatar
AbnMP13
I did this yesterday, easy as pie and now my batwing fits on oooohhhh so much easier since I eliminated that male to male adapter.
Old Feb 10, 2013 | 06:12 AM
  #228
David Heindel's Avatar
David Heindel
Stage IV
Default A different path to play
Instead of spending 400+ on the iPod interface, i'm considering adding a PARROT MKi9200 to the HK. I purchased one for my daughters Jeep and it works great. Bluetooth connectivity for iPhone music, phone and Pandora. I'm not sure there is a harness for the HK Boom system but will look into it.
Anyone look into this as an option?
Dave
Old Apr 23, 2013 | 09:43 PM
  #229
HDMac3600's Avatar
HDMac3600
6th Gear
Default IPOD Volume
Originally Posted by ChristoHD
I posted this also in another thread - but this one seems to have some serious users, so here I go...
For those who went from the 3.5 and spent the bucks on the Boom! iPod interface - did you notices a drop in "volume" or "loudness" when using the cable/interface with your iPod?
I would listen to my iPod using the 3.5/AUX jack and my volume would be between 1/2 and 3/4 - plenty of sound and clarity. So this past weekend I broke down and spent the bux on the cable interface and now I have to have the volume cranked at 3/4 to full and the "loudness" and clarity isn't there as it was with the 3.5 hook up - if anything, I was expecting an improvement, not a degradation in sound volume and quality....
Anyone else notice a diff? Anyone have an idea on what I should check?
I do like having all the controls thru the bike and one less thing on my bars, but this lack of sound bothers me. Spending that kinda dough only to get subpar results is not my frugal way. ;-)
Any thoughts and/or suggestions?
I plugged in my IPod thru the AUX jack and the volume was just not there andI have to have my radio all the way up to be able to hear it. I checked thevolume on my IPod and that was all cracked up... After doing a bunch of readingon the net I found that there is a setting in your IPod that is called"feedback" and that was turned on. Once I turned that off, it nowsounds as loud as if I were listening to the radio..
Mac
Old Apr 30, 2013 | 07:35 PM
  #230
AbnMP13's Avatar
AbnMP13
I've had my HDPD for about two years now. About to have to replace my second cable (my fault) but I will tell ya that OTMT and Iron Cross are the only places to get replacement cables. For the past month OTMT hasn't answered the phone or emails. I called IC and they were waiting to be supplied with cables from OTMT. They finally got cables in today but now I have to wait on IC to ship cables to people who bought HDPD units from IC before they will sell me a cable.
Makes me wish I had bought a unit from HD instead of aftermarket.
