iPod interface
Old Aug 24, 2010 | 03:27 PM
  #61
Ferromet's Avatar
Ferromet
Originally Posted by Harleypingman
Ferromet, I copied the wiring diagram for the SESG2 at my dealer the other day and it shows the I-Pod connector to the 35 wire connector for the SESG2 application. Perhaps it will confirm that the wiring on your CVO Ultra is the same, or identify a difference between the two applications:
http://
In any case, thanks for taking the time for the review and installation information.
Carl
Thanks Carl, that's definitely different than what is shown in the instructions. When I have a few extra moments I'll open it back up and try what's shown here. I'll post an update once I've gone there. Thanks again!
Old Aug 24, 2010 | 04:09 PM
  #62
elPrez's Avatar
elPrez
Originally Posted by jgreg65
$300 ??? I picked one up on eBay brand new from a seller on buy it now that had 100 of them for $20.00 shipping included sorry HD.
I haven't installed it only because I didn't want to hack up the dash board. Now with this kit, looks like it will be a winter project.
Got mine for $15 at Best Buy last year...not a single hole was made, I can remove it and you wouldn't know it was there.
Old Aug 25, 2010 | 08:05 AM
  #63
Ferromet's Avatar
Ferromet
http://
Carl
Kudos to Carl... thanks Man, that worked. So here's the deal, if you have a CVO bike with the Amp installed then the Tan/Blue and Violet/Gray wires need to be swapped... Tan/Blue should go into hole #31, Violet/Gray into hole #19.
Old Aug 25, 2010 | 09:14 AM
  #64
Harleypingman's Avatar
Harleypingman
Ferromet, glad to help. Two small questions: pin-out 31 calls for TN/BK wire in the SESG2 wiring diagram, but in your reply you refer to a TN/BE (blue) wire; is the wire TN/ BK (black) or TN/BE (blue)? And did the instructions with the interface provide for different wiring locations than shown in the SESG2 wiring diagram?
Also, bikes with the 35-wire connector already on the bike (e.g. Ultras and non-Ultras that have added the non-Ultra overlay harness, p/n 70169-06 for CB, XM and/or HD's rear speaker kit) should be wired the same as the CVO bike with amplifier since the amplifier doesn't use the 35-wire connector--the amp simply takes the speaker outputs from the HK head unit via the speaker connection wires, amplifies them, and sends the amplified signal to speakers--in essence the amp is wired in series to the normal speaker outputs/wiring of a non-CVO Ultra.
As for the SESG2 wiring diagram, I copied it because I was interested in how the amplifier was wired to the HK head unit and the interface wiring was "just there" when I made the copy.
Carl
Old Aug 25, 2010 | 10:14 AM
  #65
Ferromet's Avatar
Ferromet
Wire coloring
Old Aug 25, 2010 | 10:16 AM
  #66
Ferromet's Avatar
Ferromet
Carl
REVISION... MADE A MISTAKE... BELOW IS CORRECT:
Carl,
There are 5 pins that come out of the new wiring harness that is supplied with the Ipod interface kit... Tan/Red, Tan/Blue, Violet/Gray, Red/Blue & Black/Blue. No more, no less.
First, here's what the instructions that come with the Ipod interface call for:
Pin Cavity 8 = Tan/Red, Pin Cavity 19 = Tan/Blue, Pin Cavity 31 = Violet/Gray... the instructions say that if you have the bluetooth module installed to take the Red/Blue and Black/Blue pins and individually wrap them with electrical tape. It goes on to say that if the bluetooth module is not installed to insert Red/Blue into Pin Cavity 4 and Black/Blue into Pin Cavity 27. I don't have the bluetooth so I did, in fact place these pins per the instructions. It should be noted that each of the pin cavities (8, 19, 31, 4, 27) are available with a dummy in them on my CVO Ultra.
This is what was shown on your sheet and what actually worked:
According to the sheet you provided Pin 8 = Tan/Red (same as instructions), Pin 13 = Yellow/Orange (already there, no change), Pin 14 = Yellow/Violet (already there, no change), Pin 19= Violet/Gray (Different than instructions), Pin 31 = Tan/Blk (there is no tan black)... the instruction sheet was kind of blurry so I assumed that this was calling for Tan/Blue into pin 31 so that is what I did and it worked.
Hope this makes sense.
Old Aug 25, 2010 | 11:00 AM
  #67
1sweetglide08's Avatar
1sweetglide08
Here's another solution...send your radio to Iron Cross and have them install a ipod cable to your HD factory radio, the cable also charges your ipod. I paid $90.00 for it when I had my radio repaired by Iron Cross. Works great and you can extend the cable and have your ipod in your saddlebag.
Old Aug 25, 2010 | 01:23 PM
  #68
spacelord's Avatar
spacelord
Does the Iron Cross cable allow you to control the ipod from the handlebar controls?
Old Aug 25, 2010 | 01:25 PM
  #69
Stang951's Avatar
Stang951
No. They attach the cable into the AUX circuit inside of the radio. It only allows connection to play the Ipod and charge it.
Old Aug 25, 2010 | 02:45 PM
  #70
lowleveldriver's Avatar
lowleveldriver
Ferromet I should have posted what I was going through also on this forum. I just did it on the other forum. I did everything you did, what I ended up with was HD solution. They said on my 09 CVO was to reverse 19 to 31 and 31 to 19. My NIM harness wasn't,t working at all once I changed those wires the GPS worked, the iPod harness work with no problems.
Trey
