V & h power duals question ?
Old Aug 14, 2010 | 10:50 AM
My Fix's Avatar
My Fix
Question V & h power duals question ?
I know this has probably been beat up alot , but I can't find the answer !With the power duals , does the amount of exhaust exiting the mufflers is it the same on both sides ! Or is it like my stock pipes about 70 percent on the right side and 30 percent on the left side ? This is what I want too eliminate before I spend the money , I would like to know ! I do not want the true dauls , I do not like the pipe running right beside the wife's shoes on the left side ! Sometimes she wears them **** slippers and it's to hot ! Thanks in advance . . . . . . . .
Old Aug 14, 2010 | 11:30 AM
sudbury2010glide's Avatar
sudbury2010glide
Just installed a set on my sg. By doing a non scientific test(hands at tail pipes), they both flow the same amount of exhaust.
Old Aug 14, 2010 | 12:06 PM
My Fix's Avatar
My Fix
Default Thanks !
I guess that pipe equalizes the two , I assumed thats what it did but was'nt for sure thanks for the info .
Old Aug 14, 2010 | 12:58 PM
RK14SGS's Avatar
RK14SGS
V&H Tech informed me it was 45% left side/ 55% right side back when I had my V&H Powerdual headpipe. Hope this helps...
Old Aug 14, 2010 | 02:10 PM
2WheelGlider's Avatar
2WheelGlider
From my personal experiance, my left side pipe gets darker than my right side, so I do not believe they are the same pressure wise. I have only had them for 1k miles but one side is at least "richer" than the other side. May need to go back and talk to dealer about the dyno tune??
Old Aug 14, 2010 | 03:17 PM
sh57's Avatar
sh57
mine were about 60% right side 40% left side. I switched them out for the dresser duels. The pipe comes under frame just like stock. No heat on wifes foot. Sounds good and I can not tell any difference in power. I like the sound much better, now that each cylinder has its on pipe.
Old Aug 14, 2010 | 08:39 PM
Da Butcher's Avatar
Da Butcher
+1 on that experience. Mine are exactly as you describe. Have them on my Electra and the Roadie, they absolutely get darker on the left side. It's not a slight difference either. Me and Simple Green do a lot of work on the left side before even touching the right.
Oh, and did I mention tight right turns grind the pi$$ out of the heat shields? Yeah, I hundred times already, be aware should buy them and also happen to turn aggressively. Good luck.
Old Aug 14, 2010 | 08:56 PM
Stash's Avatar
Stash
They cooled my bike down nicely. However, my gas milege with pipes, & stage 1 is 30mpg, consistantly for the last 5000 miles. I'm wanting the dealer to retune. Bike runs great but all my buds with the same basic setup are getting 40mpg[/I]
Old Aug 14, 2010 | 09:29 PM
Certified Drunk's Avatar
Certified Drunk
Mine seen to flow about the same.
Old Aug 15, 2010 | 03:16 AM
Watch Guy's Avatar
Watch Guy
Default I just don't see the difference between
what the V&H Power dual's can do for you that any non cat header pipe can't. They both have a collector and redistribute the exhaust through 2 pipes. Only thing this system does is get rid of the cat's and cool down the exhaust flow. I'm wondering if getting a set of header pipes and collector from HD that doesn't have the cat would do the same thing for less $$? Hmm, have to remember to ask the parts guy about that.
cajun1957a
Jun 19, 2016 03:03 PM
DarkStar07
2014-2024 Touring Models
25
Jul 23, 2015 09:01 PM
ridedaddy
Jul 16, 2014 09:28 PM
ridedaddy
Jul 15, 2014 05:57 PM
ridedaddy
Jul 15, 2014 11:42 AM
