Hide the Horn
Old Aug 19, 2010 | 07:45 PM
  #31
maineultraclassic's Avatar
maineultraclassic
Originally Posted by drod
The horn in the factory hides the sensors and wiring for the EFI between the front and rear cyclinder. If the horn is relocated, you are looking in at the sensors and wiring.
Most of that wiring is up high and inbetween the cylinders.
The tab for mounting the horn is still there, that will block some of it.
I'll post pictures when I get it relocated.
Steve
Old Aug 20, 2010 | 05:42 PM
  #32
maineultraclassic
Horn is all relocated, that was easy. Lost the chrome cover of the Mini-Beast, painted the horn all black, and used an existing mounting hole(saddlebag ralls) to mount the horn behind the right saddlebag.
Now before I can call this job complete, I need to remove the rubber mount thingy for the horn that attaches to the top motor mount. I already destroyed it trying to remove it, so all that is left is the back metal plate that is threaded into the mount.
Any ideas on how to remove that part?
Need to remove that so I can put a HD skull medallion on that tab to "hide" it.
Steve
Old Aug 20, 2010 | 07:56 PM
  #33
glide2005's Avatar
glide2005
Default Air horn
Here's where I had mine mounted Steve. Its a mini air horn, loud as hell too. I mounted behind the rear cylinder, since I had 2 to 1 exhaust the pipe was not an issue.
Old Aug 21, 2010 | 06:19 AM
  #34
maineultraclassic
I like where I put mine, complete hidden and still loud.
I'll take a couple of pictures later.
Steve
Old Aug 21, 2010 | 06:47 AM
  #35
Max96's Avatar
Max96
Steve
Way to go Steve! I am remounting mine today (hopefully) and will post pics along with the front Howards Horn setup.
Old Aug 21, 2010 | 07:33 AM
  #36
shortride's Avatar
shortride
Kuryakyn air horn setup that mounts between the right saddlebag that I really like. Mainly because I want to mount a fan where the horn is normally located.
Old Aug 21, 2010 | 12:09 PM
  #37
maineultraclassic
Kury setup is junk...............everyone who responded to my post about them earlier this year said they fall apart or quit working.
I was ready to buy them, but changed my mind quick after hearing that.
Steve
Old Aug 23, 2010 | 04:13 PM
  #38
RCNFVR's Avatar
RCNFVR
Default Not very easy if you have filler panels
I tried to do hidden install but have the filler panels between saddle bags and the fender.With them being on space is real tight to try and get horn to fit and not rub on something.I gave up after doing it a couple of diffrent times and was not happy with the way it was.Having wrist in cast didn't help any either lol.
Robo07
Jun 30, 2018 06:18 AM
Noble Jim
Mar 5, 2014 01:38 PM
Cazimere
Jul 30, 2011 03:27 PM
jeff194
Apr 1, 2009 09:34 PM
Motorboatn SOB
Nov 15, 2008 09:42 PM
