I am going to replace the air cleaner..........I did a search and still am unsure.
Which one of the aftermarket works best/lasts........dealer says all about the same as far as performance is concerned and SE is there choice........??
I like the Performance Machine Super Gas a/c unit. It's marketed as a Roland Sands product as well. I like the looks but the better reason I like it is that it's open to the venturi in the center of the a/c. So, it pulls air through the filter around the perimeter as a normal a/c would, but it also pulls air through a separate filter directly through the center. There are a few others that have this feature but I believing more breathing is better. Bob
Also changing the pipes to Rinehearts.
The SE Heavy Breather is the best Hi Flo A/C I 've ever run.It works like a cold air intake used on cars.All the other ones that I have used draw hot air in from the motor side.W/the A/C cover.Regards,Tom ps: there is a pm that draws air in from the center,it may be cool too
Thanks for the replies...........the PM one looks like it would "flow" the best, but what about rain??
I have a rain sock that circles the filter element and has a small circular cover for the veturi area in the middle as well.
It's a black fine mesh material that breathes easy but repels rain. I leave it on all the time (in case I'm caught out in a shower or the a/c gets wet when I wash the bike. I bought it from Wimmer for less than $30 including shipping. It's a number SSRS-1. Bob
