Odometer Reset Button
Old Aug 18, 2010 | 09:33 AM
Blue Bagger's Avatar
Blue Bagger
Default Odometer Reset Button
Is this a user changeable item? I have to push mine at least 30-40 times to reset. Gets old quick. Anyone ever changed one and where do you get it, dealership? YTIA
Old Aug 18, 2010 | 09:44 AM
relli's Avatar
relli
cheap and easy. just gotta pull fairing back a little
Old Aug 18, 2010 | 09:47 AM
daharleyrdr's Avatar
daharleyrdr
Cool Odometer reset button
I had mine changed twice on my 08 EGC once by the dealer under warranty, the second one by a dealer on the road not under warranty cost about $50 with labor, someone said pull the fairing back a a little bit????
Id pull off the outer fairing. Its a cheap part under $10 I was going to do it myself but you had to cut splice and solder the wires on my year anyways so unless youre comfotable with electrical Is let the dealer do it.
My two cents thanks BV
Old Aug 18, 2010 | 05:16 PM
Blue Bagger
Thanks. Guess I'll check the local dealer and see if he carries it.
Old Aug 18, 2010 | 05:19 PM
Iceman24's Avatar
Iceman24
Not to be demeaning, but are you holding the reset button in for a few seconds to reset? Usually it takes ~3-5 seconds pressed to clear to "0"...
I could be way off & yours is defective, but wanted to make sure you're trying the reset correctly.
Old Aug 18, 2010 | 05:24 PM
Blue Bagger
Its a good point but yes, I've held in for up to a minute at times. Sometimes it will reset within a few seconds other times it takes minutes. So if I am to understand correctly it is in the actual button, not the speedometer unit???
Old Aug 18, 2010 | 05:29 PM
Iceman24's Avatar
Iceman24
OK...yes then it's the button acting up on yours. Pain to swap because of wiring, but agree w/daharleyrdr to let HD replace (less headache). Good luck!
Old Aug 18, 2010 | 06:39 PM
bagman1's Avatar
bagman1
You can always try unscrewing the weather proof cover on the button and spray some electrical contact cleaner or some WD 40. Usually theres carbon build up in the switch. I bet this fixes it for you.
Old Aug 18, 2010 | 07:04 PM
Turbo Turtle's Avatar
Turbo Turtle
Just don't have the power on while you spray. But do push the button repeatedly while spraying the electrical contact cleaner in it. CRC make a good one, and it's as cheap as the little bitty cans you can get at Radio Shack. also, do not try to use the button until a couple of hours after. You want the button assembly to be dry again before you use it, as it might could short it out.
aka Bob
Old Aug 18, 2010 | 07:15 PM
Harleyboyddk's Avatar
Harleyboyddk
Mine fell into the fairing while on a ride leaving a nice hole in the dash for the rest of the ride. Check tightness every now and then. Another thing, the nut on the fuel door lock would always loosen up. Recently after seven years, I wised up and used loctite and put a stop to that. Put a wrench on it instead of finger tight at the station.
