Throttle problems!
Old Aug 20, 2010 | 05:30 AM
1Digger's Avatar
1Digger
Default Throttle problems!
I put new bars on my 99 RKC, EFI. I needed a little more pull, and these are narrower. The throttle worked perfectly before I removed it. Now, it drags and doesn't snap back to closed. I have greased the bar with some grease I had around, axle grease. Anyway, I didn't disassemble the throttle, the cables aren't binding, and I am stumped. Do I need a lighter grease? I did a search and didn't really find anything similar to mine. Thanks in advance.
Old Aug 20, 2010 | 05:43 AM
geezer glide 56's Avatar
geezer glide 56
[quote=1Digger;7169447]I put new bars on my 99 RKC, EFI. I needed a little more pull, and these are narrower. The throttle worked perfectly before I removed it. Now, it drags and doesn't snap back to closed. I have greased the bar with some grease I had around, axle grease. Anyway, I didn't disassemble the throttle, the cables aren't binding, and I am stumped. Do I need a lighter grease? I did a search and didn't really find anything similar to mine. Thanks in advance.[/quote
Loosen the 2 t27 fasteners that hold the master cyl.on and the 2 t25 fasteners that hold the switch housing and slide the whole assembly out just a fraction...It is binding on the end of the handlebar.
DigbyHD
May 30, 2014 05:47 PM
rooti
Feb 9, 2014 10:56 AM
bigrob219
Jun 21, 2012 06:06 AM
ed gien
Apr 11, 2011 08:16 PM
blackedout08
Feb 14, 2010 04:17 PM
