First post, first bagger, same old questions.
Old Aug 25, 2010 | 10:26 PM
peener's Avatar
peener
Default First post, first bagger, same old questions.
Hello all, I have reading this forum for a while now, and have been building custom bikes for 30+ years and I have now moved up too a bagger, a 2008 R.G. My plan is to custom it up a bit with the following, Sinister rear fender, Dragonfly"s new front fender, extended tanks, narrowed seat H.D. seat, sectioned and narrowed tour pak and a complete candy paint job. I can do all of this by myself. However these are my questions. I will be lowering the rear by 1 inch using blocks, using tri glide 3 degree trees which should lower the front end. Since I like my bikes low should I use a 16 or 18 inch rear wheel, is the 18 any taller compared to a stock rear wheel and tire? I also plan on a 21 front wheel, which I have read will raise the front by one inch, so with that in mind will I need to lower the front end to make it level, if so how much? I'm thinking 1/2 to 3/4 inch, does anyone make a lowering kit in those small amounts or is there another way. Thanks for any help to my somewhat odd question.
Old Aug 25, 2010 | 10:57 PM
dohadex's Avatar
dohadex
Wink Custom bikes for 30+ years?
What kind of "Custom bikes" did you build for 30+ years? Your questions disqualify your credentials sir...
Hmmm....raising it 1"....then lowering it by...ummm....6?
Sorry newb. Just joshin ya. Welcome to the forum.
Old Aug 25, 2010 | 11:28 PM
peener's Avatar
peener
Well, let s see, I have had feature bikes in easyrider, Iron horse, hot bike, I have been a professional bike show judge for over 20 years, I have built from the ground up cb 75o's, one with a blower, a kz 900 that was the internation radical bike champion in the Isca car show circit in the eighties, I currently have 90 Fxr that looks like a mid fifties Buick with port holes, a 2005 88b hardtail custom, a very wild 2001 deuce, a Ness style digger xl, a custom victory pitboss, and I have built 2 xl's for my wife, one a 2007 that I turned into a mini baggerwith the bags and rear fender appearing to be one piece. Sorry if I did not explain my bike history and I see you were joshing and maybe I'm defensive about my bikes, but if you were from the Pacific n.w. you may have seen my work. Once I agin I was simply trying find a way to make my bike level with my intended mods. If I was not clear sorry.
raptorgabe
Jul 27, 2018 02:20 AM
Jesse_the_kid
Jan 22, 2010 02:25 PM
1DOG,1GLIDE
Jan 5, 2009 12:18 AM
moggsy
Nov 28, 2008 11:15 PM
tna1000
Oct 30, 2007 10:43 PM
