I can't honestly say for sure if that's whats happening with mine.....I haven't payed that close attentioin to it. What I have noticed is that the music is not as loud as a cd or the radio.....the volume must increased on the radio, if thats because of the way the songs are recorded on the ipod or not, I don't know....haven't had time to see if a person can record the songs at a louder volume on the ipod...
Many iPod™ type devices have equalizers, bass boosts, loudness contours, and “maximum volume” settings etc
built in. It works best to shut all of this off so the unit is “flat”. We suggest putting the volume of your peripheral
device to around 50% of the way up, and with your factory radio’s “AVC” or Automatic volume control off, put
the radio up to as loud as you would typically have it when riding around. Then start raising the volume of your
peripheral device to the point you start hearing some distortion. Put the AVC back where you like it on your
factory radio, and your ready to go. This is a general way to level match. Since each peripheral device has
different features, and different audio settings, you can now “mess around a bit” by experimenting with your
peripheral devices equalizers etc until you get a sound that works for you.
There advice was for "peripheral" audio devices with the above for Ipods.
Carl
PS: Copy and paste resulted in the line formatting being "off." But the text is there.
Only thing with that is that the ipod is connected to the module using the data port not the earphone plug. "messing" around with the settings isn't possible when hooked up with the data cable to the module, it is when hooked up to the aux port using the earphone plug.
with your installed module do you notice more of the lyrical sound coming form the right side speaker than the left? I installed it on a 2009 flhtc and this is what i am hearing.
ENCret, see the following thread to solve your problem...
I believe what ferromet is referring to is that the original instructions for the interface module had a mistake regarding the wire assignments for pinouts 19 and 31. In the original instructions, those were wrong and should be reversed. HD issued revise instructions dated Sept. 14, 2010 that corrected the mistake.
I have noticed as well that the vocals only come from the right speaker....gonna try the repining of the plug as per the revised instructions....the other thing I've noticed is that the volume isn't as good when using the ipod, maybe switching the 2 pins in the plug will cure that as well.......will repost if it works.
The pin switch works... also, be sure that the volume limit on the ipod preferences is set all the way up.
Here's the best combo I've found:
Volume limit... all the way up. Volume all the way up.
EQ set on "Bass Reducer"
Sound Check: Off
AVC on HK Radio: All the way up.
Treble on HK Radio: All the way up.
Bass on HK Radio: Between Mid & Max
Being a Pro audio professional, we use and see ipods used more & more in my industry. Accordingly, have tested the outputs of all / most models of IPODs for distortion and have pretty much concluded that the best overall setting for the volume limit is at about 90%. The "last" 10% has a ton of distortion contained.
Well, I did the pin switch (19 and 31)....WOW, what a difference, the volume is the same as a cd and the radio and the vocals are coming outta both speakers, not just the right side.......Thanks Ferromet for posting that link to the updated instructions.
Suggestion: Edit your first post to include this link to the revised instruction sheet so others can avoid the problem encountered if they have the original, wrong instruction sheet:
