Road King vs Heritage Softtail
Old Sep 15, 2006 | 03:41 PM
clwilli's Avatar
clwilli
Stage I
Default Road King vs Heritage Softtail
I can purchase a 05 in either model...would be the 1st Harley I have ever owned....What is the Pro's/Cons on the models....I'm a 6'3" male, 210 lbs....both seem to be very similar. THANKS for you thoughts
Old Sep 15, 2006 | 03:49 PM
t_m34's Avatar
t_m34
Default RE: Road King vs Heritage Softtail
I'm about your size (6'4", 215) and went with the Road King. I almost bought the Softtail, too, but the cruise control and (with my Classic) the white walls sold me. One thing I noticed about them (I've ridden the Softtail before) is you should be prepared to modify the handlebars of the RK. I ended up slouching down to reach them, which killed my neck and back. The Heritage Softtail Classic has higher bars and was more comfortable. I put the RK higher handlebars on and it cured the problem (and you don't need to redo the wiring/cables).
The RK ride is very nice, though. Lots more travel IMO and more comfortable. The air suspension in back, though, when you hit big bumps/dips, can really stiffen up. I went over a hump in the road down in Florida (the bike had no weight but me on it) and the rear end flew up, just about dumped me. So be prepared to adjust the suspension, too.
You can't go wrong with either as far as looks are concerned.
AK_Hog_Herder's Avatar
AK_Hog_Herder
Test ride them both then decide.
Old Sep 15, 2006 | 03:51 PM
Manish_Hawg's Avatar
Manish_Hawg
Road King...but I am biased.
Old Sep 15, 2006 | 04:14 PM
MixedNuts's Avatar
MixedNuts
Nice Bike man!!!
I bought the same one.
Old Sep 15, 2006 | 04:55 PM
Domestic Violence's Avatar
Domestic Violence
RK- better bags, nicer looks, air ride, cruise ctrl... and, if im not mistaken- the Heritage only has one disc brake up front... RK has 2
Old Sep 15, 2006 | 06:02 PM
Firetender's Avatar
Firetender
Wow! Road King. So easy - locking hard bags, yes to dual front brakes, pitch the handlebars for a set of 16" Wild Ones or something with good reach and hit the road. Oh yeah, an oil cooler helps with high temps if you're worried.
'01 FLHRI, red
95", SE203 cams
HD Oil Cooler
16" Wild Ones
Russell stainless lines
Detachable backrest/nostalgia luggage rack
Blackwalls
3-way brake light kit
Old Sep 15, 2006 | 07:01 PM
Geoseismic's Avatar
Geoseismic
I'll have to disagree with the first two. The Heritage bags have allot more room than the RK, mostly because they don't have to fit around the rear shocks, which are mounted underneath and out of the way on a softail. It was the looks of the FLSTC that turned me away from the RK. FLSTC is "dripping" with chrome and has a far cleaner looking line than the RK. Air shocks and cruise are nice, but I didn't feel that those two items were important enough to influence my buying decision. Of course, you can always add air shocks and cruise to an FLSTC. As far as cruise control goes, I rarely use it in my car or truck and didn't figure I would use it much on the bike either.
Probably the most important issue is the difference in the way the two bikes feel. You sit in a Heritage while you sit on an RK. The TC88B engine is silky smooth both at idle, and at speed while the TC88A will shake the crap out of you at idle and low speed and only smooths out when you get up to cruise speed. Of course you will hear people complain about TC88B vibration at higher RPM - I wouldn't even call it a vibration, but a slight buzz.
Got me on the dual front disc brake, though I don't seem to miss the extra rotor on my bike. Guess I could say the brake jobs are cheaper on the softail!
Drop a set of passanger foot boards and a tour pack on your Heritage and you have as comfortable and as capable a cruiser as any HD touring bike, without all the bells and whistles (like radios that crap out), and a heck of a lot better looking!!!
Old Sep 15, 2006 | 07:08 PM
gunrunner's Avatar
gunrunner
Heritage, has weak shock system for heavier riders, you being your size if you add a passenger you will bottom out at every bump, plus the ride isnt as good and it will vibrate more and have less power due to its counterbalance system that robs horsepower. Not to leave out the hreitage also has a 31degree rake and will not handle even close to as good as the 26 degree touring models. Any of the touring models are better for the road than the heritage.
Old Sep 15, 2006 | 07:24 PM
GliderXXX's Avatar
GliderXXX
Been the Soft Tail route....no comparison to a touring bike. I'd call that hiway vibration a bit more than a buzz
