View Poll Results: do you use heel shifter?
yes
678
58.55%
no
381
32.90%
sometimes
99
8.55%
Voters: 1158. You may not vote on this poll
Old Oct 30, 2010 | 09:22 AM
  #61
Troubleman's Avatar
Troubleman
I use mine to find neutral. Also when I get an occasional gout attack, it's a must.
Old Oct 30, 2010 | 09:30 AM
  #62
tx-skydiver's Avatar
tx-skydiver
I love it. In fact, I've never used the toe shifter on any of the tourers I've ridden.
Old Oct 30, 2010 | 09:32 AM
  #63
frenchbiker's Avatar
frenchbiker
How do you shift in 1st gear and how do you downshift?
Old Oct 30, 2010 | 09:55 AM
  #64
JohnnyC's Avatar
JohnnyC
Never had a heel shifter until I bought my Tour Glide. I adapted to using it right away.
When I replaced the charging system I set it as low as possible, and set the forward control just high enough to get my boot under it if needed. Now that they are positioned for me there is no other way I'd prefer shifting.
I like the feel of moving forward and just lifting my heal after each shift. I seem to get more positive shifts by using it too.
For those who feel it's in the way ... Adjusting it to your positioning may be all you needed to do to make it work correctly.
Question for all those who strip it off their bike before they even tried it .... Why?
Old Oct 30, 2010 | 09:56 AM
  #65
BLK08ROCKERC's Avatar
BLK08ROCKERC
The only reason I use mine is to find neutral so it will be going in the parts pile this winter.
Old Oct 30, 2010 | 10:10 AM
  #66
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Then how will you find neutral?
Old Oct 30, 2010 | 10:16 AM
  #67
ny2az's Avatar
ny2az
Took mine off,and put a chrome cover over the shaft....
Old Oct 30, 2010 | 10:22 AM
  #68
DrPlastic's Avatar
DrPlastic
Like JohnnyC I have mine st up to use it both ways. My toe shifter is up high enough to stick my boot under to toe shift and my heel shift is set low to so I almost don't have to take my foot off the boards to heel shift!
Old Oct 30, 2010 | 10:26 AM
  #69
Navy UC Rider's Avatar
Navy UC Rider
I love it and would not go back, my fit are the right size that it works perfect.
Cale
Old Oct 30, 2010 | 10:42 AM
  #70
Xzotik's Avatar
Xzotik
One of my first mods was to remove the heel shifter. No regrets!
