Monkey bars... How hard is install?
Old Nov 7, 2010 | 10:54 AM
mazman's Avatar
mazman
Default Monkey bars... How hard is install?
Gonna get some monkey bars this winter and tackle it myself. Goin for the 10s . I got 09 FLHT. Don't have the $ to spend on labor, so for all the guys who has done this, how much of a PITA is the wiring. Any tricks to getting them through? Don't have ABS. Also new cables for 10's? Not really mechanically inclined, but I think I'm up to the challenge! Any help, advice, tips, or tricks appreciated!
Old Nov 7, 2010 | 10:58 AM
PistonPuller's Avatar
PistonPuller
Wiring is only a PITA because it takes patience. It's not hard, just can be tedious. Don't think you will need new cables for 10's but not 100% sure. One trick I used a piece of small chain to run through the bars, then taped the wiring and pulled it through. Another suggestion would be to go with a higher bar. I have 13's and could not imagine going any lower. In fact I am starting think I should have done 16's but I like the look of the 13's. Lots of info here.
Old Nov 7, 2010 | 11:15 AM
slothy's Avatar
slothy
i was told no on different cables, i ordered 10's - just have to reroute the wires and clutch cable alittle bit
Old Nov 7, 2010 | 04:07 PM
glide2005's Avatar
glide2005
10" is not a couple of inchs more than stock. Not worth the hassle to me. Get at least 13" or 16". You can thank me later. Besides, your arm pits will allway be dry, how cool is that.
Old Nov 7, 2010 | 04:33 PM
kjelders's Avatar
kjelders
Like others have already mentioned, I would go 12.5" at least or 14". I went with Wild 1 12.5". Parts of the install can be a PITA, but get friend to help and a manual if you don't already have one.
Old Nov 7, 2010 | 06:03 PM
rg_dave's Avatar
rg_dave
On the wiring get the TBW extension to put the plug at the bottom. Don't heat shrink you wires too tight. You wan't them to be flexible and no wrinkles. Use a small chain to feed your pul line through. I used weedeater string, I stole that idea from someone here. I think you will need to go +4 on the clutch cable. Lots of guys have said it pulled even with the 10s. My two cents is go at least 12s. I started to go with 10s went with 12s, really like them but if I do it again I will go with 14s. The hands over the fairing thing is no big deal, they look great, and they are much more comfortable.
Old Nov 7, 2010 | 06:27 PM
neano62's Avatar
neano62
Dont let nobody b/s ya. they are a pita to install! If your UP for the challange, sounds like your ready? I used vasoline and kept the original heat wrap on. Tape your weed eater string on, and lube it up w/lots of petroleum. 10" bars measure out at 12-1/2", are very comfy and my hands aint above my shoulders.Make sure Yaffe sends you the instructions, they are a MUST for install
Old Nov 7, 2010 | 07:29 PM
FLHXTC's Avatar
FLHXTC
I started to go with 10's, but went with the 12's instead. Glad I did, they're perfect for me. I used a pull chain from ceiling fan, and lube for pulling electrical wires. I didn't extend the wires. It's a PITA, but if you get frustrated, walk away for a few. Go for it, you'll love them!
Old Nov 7, 2010 | 07:53 PM
Gruamach's Avatar
Gruamach
I dedicated an entire evening to the wiring.......trust me, you'll need it.
And by "evening" I mean, I disassembled at about 3 pm. Took break for dinner, but still didn't finish til after midnight.
Old Nov 7, 2010 | 08:05 PM
drewski1325's Avatar
drewski1325
Use a string and a shop vac to suck the string thru the bars from one end to the other. Then use the sting for a wire pull. Works slick.
