Lift or Jack?
Old Nov 12, 2010 | 09:39 AM
2manytoys's Avatar
2manytoys
Default Lift or Jack?
Just moved into a new house and finally have room for doing my own maintenance. Was wanting to know which way to go. I am leaning towards a lift because it would raise the bikes higher which would require less bending over. But with a jack it would seem that there would be more room to work.
I have a Streetglide and the GF has a Fatboy lowered 1 1/2".
Any input would be helpful. Thanks
Old Nov 12, 2010 | 09:43 AM
62hdbiker's Avatar
62hdbiker
I had a jack for many years. I got a table lift and never used the jack again. I put the optinal side extensions on it so I could ride up on it and I park a bike on it all the time. I also replaced the front wheel vice with a Condor wheel chock. You jut ride up and get off. That was it really doesn't take up any space.
Old Nov 12, 2010 | 09:51 AM
djl's Avatar
djl
I have both and prefer the lift unless just raising the bike for something quick. The lift does raise the bike higher so you can sit on a stool and work, also provides unrestricted access to the under workings and a "table" where you can place your tools and parts. The downside of the lift is that if you decide to sell it, the weight makes handling and shipping a PITA, when not in use, it takes up floor space and you can't move the lift around like you can the jack. Having said that, I would not want to tackle some of my projects with a jack.
If you decide to go the jack route, get the J&S jack; more $$ but worth the extra cost. If the only work you see yourself doing is fluid/filter changes and tires, a jack is all you need.
Old Nov 12, 2010 | 09:53 AM
PistonPuller's Avatar
PistonPuller
If you have the room and the cash for a lift go for it. I use a jack without any problems, but I would rather have a table. Just right now I would rather spend my money on more parts
Old Nov 12, 2010 | 10:31 AM
oldandbusted's Avatar
oldandbusted
I have both. If you have the room and the budget its the way to go. I use the the jack every time I wash the bike, it makes cleaning the wheels and tire easy and you you dont have to get down on the wet ground to do it. The lift excels at alot of different maintenance jobs and lets you work like a gentleman with a place to put your tools and parts within easy reach
Old Nov 12, 2010 | 10:55 AM
2black1s's Avatar
2black1s
Likewise, I have both. Got the lift years ago and just recently got the jack. The lift is great for almost everything. One thing you can't do very easily on the lift is remove the front wheel/tire. The jack on the other hand makes front wheel removal easy. The jack is also great for getting the wheels off the ground when cleaning them. It's nice to be able to rotate the wheel. Before the jack I use to do a section of the wheel then roll the bike and do the next section, then roll it again and so on - pain-in-the-***!
And one final point. I'm never concerned with the stability of the bike when it's on the lift. I can't always say that with the jack.
Old Nov 12, 2010 | 11:03 AM
petemac's Avatar
petemac
For the stuff I do a good jack is fine. I have a J&S jack and love it.
Old Nov 12, 2010 | 11:38 AM
kjay58's Avatar
kjay58
+1 on J&S Jack....
Old Nov 12, 2010 | 11:41 AM
bluffalobob's Avatar
bluffalobob
If I had the room, I'd have a lift. But that's a big hunk of metal that would just sit there unused 95% of the time.
Since I don't have that kind of space, I use a J&S jack, and it works fine for me.
Old Nov 12, 2010 | 12:15 PM
Jinks's Avatar
Jinks
Best of both worlds. I have a "Blackjack" system. It's a good "jack" with a separate table that the "jack" will fit under. I can either raise the bike by the frame to work on tires/wheels/ suspension, or roll it up on the table & lift the whole thing. When not in use the table stands on end against an unused wall in the shop. Unfortunately they're no longer made............
I have a friend at an aftermarket shop that uses a chain hoist instead of a "jack". He uses tow straps at hard points on the bike. Fastens the other end of the straps to a hook on the chain hoist, & lifts one end at a time to work on tires/wheels/suspension. Saves his table lifts for bigger projects.
