Air ride installed...
Old Dec 28, 2011 | 01:04 PM
  #221
ChoptXLC's Avatar
ChoptXLC
I bet home depot has them
Old Dec 28, 2011 | 01:20 PM
  #222
todderickson's Avatar
todderickson
Has anyone thought about putting a height control valve in one of these setups? It would control the pressure to keep the ride height the same regardless of the weight of the load? I suppose you would need a small air tank then and where do you mount it.
Old Dec 28, 2011 | 02:02 PM
  #223
customsoftail200's Avatar
customsoftail200
Originally Posted by OutlawBagger
I got my push locks from work. I had to get a couple adapters so I went to a rubber and gasket company close by. I would think a truck repair Co. or someplace that sells hose's. Are you in Old Bridge NJ?
Yes, Old Bridge, NJ. Thanks, I'll look around for a truck repair place.
Home Depot doesn't carry anything for 1/8" line, the smallest is 1/4".
Old Dec 28, 2011 | 02:34 PM
  #224
OutlawBagger's Avatar
OutlawBagger
http://www.vanhydraulics.com/product.html
http://www.hoseshopinc.com/catalog/contact_us.php
http://knottsco.com/
Hope these are close
Old Dec 28, 2011 | 05:14 PM
  #225
coolerman69's Avatar
coolerman69
I did push locks on my set up. Hell we run them at work. They work great there and they are holding a lot more than 100 psi.
I'm sure push locks would work fine I just didn't have any available locally so brass it was. They definitely would be quicker/easier to install.
Old Dec 29, 2011 | 10:01 AM
  #226
VegasKen's Avatar
VegasKen
Does anyone know where I could put the compressor withOUT putting it in a bag? I have a 2012 Road Glide that has the ABS module where most people seem to be putting theirs.
Old Dec 29, 2011 | 03:28 PM
  #227
gambueller1's Avatar
gambueller1
Default Module relocation
I just finished doing my install on my 07 Road King today and I had to make room on the right side of the bike where it seems most people have space.
I will be posting a full write up with part numbers, prices, pics and issues soon.
I can honestly say that insight from others made this a pretty straight forward job.
That being said I did have to figure a few things out for myself and that which I did may have only been specific to what I did.
Old Dec 29, 2011 | 06:07 PM
  #228
coolerman69
Not very familiar with RGs but look under the faring. Outlaw bagger put his behind the left side plate.
Old Dec 29, 2011 | 07:53 PM
  #229
OutlawBagger
Try looking behind the left side pannel. You can look at my post air ride install part 2 for pictures. Hope this helps.
Old Dec 30, 2011 | 04:24 PM
  #230
DMC1's Avatar
DMC1
Put the Gabriel 49304 shocks on today and took a ride. I rode it as far down as it would go without being "rigid". Bike rode a little stiffer but tire did not rub at all. When I had the bike in the air I felt inside the fender. There are no wires running inside of my fender. With the extreme mod seat from MeanCity Cycles and these shocks I feel like I'm sitting on the ground.
Since I ride solo about 98% of the time I may not even go to the trouble to put a compressor on mine. May put the compressor on later. I ride it low anyway. I basically just replaced the factory setup and lowering blocks I was using to the new Gabriel setup. I like the way it sits.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
