Primary Capacity
Old Nov 22, 2010 | 03:53 PM
rscott's Avatar
rscott
Question Primary Capacity
I'm a newbie to H-D bikes My owners manual calls for 38 oz. for my FLTRU Is that what everyone is putting in or are you just adding a quart? Is the capacity different on rubber mounted engines from the counter balanced models?
Thanks
Old Nov 22, 2010 | 03:57 PM
BBStacker's Avatar
BBStacker
Stick with what your manual tells ya. No different than your cage if it says 5 quarts thats what it takes. You can't just dump in a ballpark amount and hope it all works out.
A quart is 6 oz less than recommended might not make a major difference over a short run but in long haul......
Old Nov 22, 2010 | 03:58 PM
07RoadHawg's Avatar
07RoadHawg
Everyone that has an '07 or newer uses 38oz. The difference came with the TC96 engine and the 6 speed trans. The primary design is a bit different and requires a bit more fluid to get the level up to the proper spec.
Old Nov 22, 2010 | 04:03 PM
Ronp42's Avatar
Ronp42
Account Retired
38 is right. When I change mine, It's always after I bring it to operating Temp.I first loosen the Torx bolts on the Derby cover slightly. Not enough to leak, but know I won't have a problem with any. I start draining the Primary with the bike on the jiffy stand. Then I put it on my Jack and raise it level. Always seem to get a little more oil out this way. When I refill it, I put in close to 38 OZ's, checking to make sure the oil is up to the bottom of the Clutch pack. You do not want to overfill it!
Old Nov 22, 2010 | 04:09 PM
Mike T's Avatar
Mike T
I've noticed the fluid will turn darker quicker if you under fill it.
Old Nov 22, 2010 | 04:13 PM
D2R's Avatar
D2R
I've always drained mine in a measured beaker.It's always been within an oz. or 2 of 38 ozs.
Old Nov 22, 2010 | 04:46 PM
vickon's Avatar
vickon
Just did my '08 FLHTC and I put exactly 38oz., I've got 32,500 miles on the stock original clutch and it still going strong, no slipping ...go with what the "book" says, can't go wrong.
Old Nov 22, 2010 | 04:52 PM
rscott's Avatar
rscott
Thumbs up
Thanks guys Thought it would be best to check here to get right answer quickly
Old Nov 22, 2010 | 04:54 PM
harleyflyboy's Avatar
harleyflyboy
Unless you remove the complete outer primary, then it is 45 ounces.
Born2cure
Apr 27, 2012 08:34 PM
deadman77
Apr 11, 2010 10:37 AM
joesride
Mar 28, 2010 10:31 PM
fatbob
Jun 15, 2008 07:41 PM
firestar99
Jul 28, 2006 02:03 PM
