Cam Bearing Depth
Old Nov 24, 2010 | 10:49 AM
rm4040's Avatar
rm4040
Default Cam Bearing Depth
What is the best way to insert cam bearings to proper depth if you don't have a special tool
Old Nov 24, 2010 | 11:09 AM
pmcburne's Avatar
pmcburne
Lay a good straight-edge across the timing chest gasket surface. First measure to the casting beside the bearing, then measure to the bearing outer race. The difference is your recess depth.
Old Nov 24, 2010 | 11:17 AM
Mike T's Avatar
Mike T
If you're installing a new cam,use your old cam to install the bearing.The back of the bearing journal will stop the bearing.
Old Nov 27, 2010 | 07:20 AM
2009blackpearle's Avatar
2009blackpearle
Default dont push in until it stops
your not supposed to push it in until it stops, as in last quote until it hits the bearing journal. it is a set depth measured from the face of the cam box. you should have taken a reading before you pulled the stock ones out. pushing it in until it hits the bearing journal runs the risk of bending the outer edge of the bearing casing over into the bearing needles. the whole thing is in the shop manual for about 100 bucks.from the edge of the face of the cam box to the visible edge ( outer edge) of the bearing is 3.10 inches in the manual.
I made my own pusher, i didnt want to spend 400 bucks for a harley one, Im sue if you hammer them in they will get damaged, the fit is very tight. as you can see in the picture I am measuring from the out side of the ruler face so you have to subtract that thickness from the reading to get the real depth. you can measure though small holes in the harley version and leave the plate in place , I have to remove mine , its only 4 bolts a couple of times until I hit the 3.10 reading
Attached Thumbnails Cam Bearing Depth-74-home-made-pusher.jpg   Cam Bearing Depth-77-bearing-pusher-insert.jpg   Cam Bearing Depth-83-pusher-in-action.jpg   Cam Bearing Depth-84-checkiing-depth.jpg
Old Nov 27, 2010 | 07:25 AM
2009blackpearle
Default look in back of bearing whole
if you look real hard you will see the small lip in the back of the bearing socket. hammering the bearing in you run the risk of breaking off the small lip in the back of the bearing well. you can feel it with your fingers it is a very thin lip, I dont think you will be able to feel the bearing stop when you bottom it out.
Old Nov 27, 2010 | 07:43 AM
Mike T's Avatar
Mike T
I disagree with you.You can feel it when it bottoms out.
Old Nov 27, 2010 | 08:14 AM
2009blackpearle
Default good luck bending the lip of the bearing over
good luck with that. 30,000 piece of bike aint worth guessing when u hit bottom
Old Nov 27, 2010 | 08:37 AM
BadPiggy's Avatar
BadPiggy
All this hokus pokus measuring isn't needed to install these cam bearings.
These Twinkies are light years beyond the old motors...Evo's - Shovels - Etc....
You had to measure everything for proper cam installation on those.
To answer the OP sensibly...after you get the bearing most of the way in...use the ratchet side of a socket larger than the cam bearing bore...shove a socket extension in the socket...lightly tap the extension with a hammer, or your fist if you prefer...until the socket hits the case...that's plenty seated.
Old Nov 27, 2010 | 11:59 AM
thereal142's Avatar
thereal142
Yeah, but the cotangent of the socket (especially if it's a CHROME socket) should be extrapolated against the arc of your fist. Also depends on ambient moon phase and how much Wild Turkey is available.
Old Nov 27, 2010 | 12:34 PM
mtclassic's Avatar
mtclassic
I would not use your way for two reasons, one is not that easy to feel when bottomed out and not worth damaging the bearings. Proper tool is fairly cheap and works great. If it has worked for you keep using it but I have done a bunch and would not go that route.
EarlB
Engine Mechanical Topics
15
Aug 24, 2018 09:10 PM
SiggerTX
Jan 3, 2016 09:22 PM
jmn1960
May 28, 2013 09:26 AM
murf1
EVO
13
May 3, 2010 04:30 PM
wadejesu
Exhaust System Topics
Jan 9, 2008 11:53 AM
