heat wrapping exhaust
Old Dec 5, 2010 | 02:25 PM
cardoctor's Avatar
cardoctor
Default heat wrapping exhaust
getting ready to have my heat shields ceramic coated black this winter and was thinking
about wrapping my pipes under the sheilds too help with some of the heat issues .
who has actually done it and was it worth the effort
Old Dec 5, 2010 | 03:10 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i wrapped the crossover to help with heat ,but the wrapping can hold water or mosture and cause corosion.better bet would be get headpipe coated in and out.
Old Dec 5, 2010 | 03:11 PM
bigdumbnoitall00
it was cheep and easy to wrap used sheild clamps to hold down the ends of wrapping.
Old Dec 5, 2010 | 03:37 PM
cardoctor's Avatar
cardoctor
did it help with the heat?
Old Dec 5, 2010 | 04:47 PM
Mike's Avatar
Mike
I've done it, not for awhile, and not on my current bike. It does help with the heat, and theoretically is a performance enhancement. (keep the gasses hotter, they travel faster). There's gonna be some guys that will tell you that you'll corrode your exhaust under the heat wrap, but that never happened to either of the bikes I had exhaust wrap on. The key is to get a good, tight wrap, and you won't have any problems.
The last bike I had with heat wrap on the exhaust was an old Bonneville bobber. The exhaust consisted of a couple of straight pipes, wrapped with header tape and a lollipop in the end. Ran it that way for a couple of years with no issues whatsoever.
Old Dec 5, 2010 | 10:18 PM
Navy UC Rider's Avatar
Navy UC Rider
When you get it done, please post how well it helps with the heat. I have been kicking around doing this as well, just slow to pull the trigger.
Cale
Old Dec 5, 2010 | 11:38 PM
CT-Bagger's Avatar
CT-Bagger
Sounds like a good idea.
Old Dec 6, 2010 | 02:28 PM
kingwoodlee's Avatar
kingwoodlee
6th Gear
Did it over 1-1/2 years ago to my V&H monster oval head pipes and yes it does make a difference on my 07-Road Glide as far as lowering the heat. Of couse, we did use a tuner at the same time the pipes were added so not so sure about the heat wrap by itself. I found a grey color wrap, and had the dealer install it while putting the new pipes on. I was told that the head pipes could crack over time due to the wrap holding so much heat in, and with the harley vibration helping to stress the metal, but so far no problems. The head pipes are noticeably cooler to the touch though. Hope that helps.
Old Dec 6, 2010 | 04:33 PM
62hdbiker's Avatar
62hdbiker
I did my 97 Heritage with a 107" 10.5/1 motor about 5 years ago. It helps alot.
I also did my new 2011 when I got rid of the cat. Heat sheilds cover the wrap nicly. I make sure I run the bike after washing to evaporate any water in the wrap.
Old Dec 6, 2010 | 07:49 PM
bigdumbnoitall00
did it for the wife the crossover on my 07 was cooking her right foot, it was a slight improvment, but nothing compared to adding a proper tune.
oricko
Aug 7, 2013 09:35 PM
lateralus
May 30, 2012 06:59 PM
sacto95827
Jan 21, 2011 07:33 AM
scooter34
Apr 4, 2009 12:31 PM
JDixon
Mar 4, 2009 12:15 AM
