cams
Old Dec 27, 2010 | 08:34 PM
ken1960's Avatar
ken1960
Default cams
has anyone tried or heard of the s&s 585s cam they have built in compresion realeases in them. i did hear one run today with the revoltion 107 kit no vale rattle at ,like the woods has
Old Dec 27, 2010 | 08:48 PM
Biggzed's Avatar
Biggzed
The original S&S 585 is a very good cam when matched with the right compression/head work. If they simply reproduced it with the "easy start" feature, then it should be equally good. It will only be good with complimentary components though.
I've got a good friend running a set of 585's in his 95" with BC Gerolamy stage 2 heads at 10:1 compression. It rips, especially above 3000 rpm. It's flat nasty sounding with his Thunderheader.
Zach
Old Dec 27, 2010 | 09:42 PM
VegasBigPapa's Avatar
VegasBigPapa
6th Gear
I am running the S&S T585G's with a 95 kit in an 06 Electra with SE slipons. Runs like a beast 3000+ but you will HAVE to run a tuner like a SE race tuner, Powercommander or a Fuelmoto tuner (same as PC). I had major ping issues with a fuelpack and changed to the Fuelmoto....works great and no HD download.
Old Dec 30, 2010 | 03:01 AM
Trev707's Avatar
Trev707
Stage I
I have a stock 06 roadglide, with 2:1 thunderheader exhaust , big sucker af, and a power commander3 and need to know what cams 2 go with?? Screaming eagle 203's or S&S or Woods 510s? or is there a better cam for my stock set up????
Old Dec 30, 2010 | 06:43 AM
Bodean46's Avatar
Bodean46
I had the S&S 510G's installed in my stock 88" and they work really well from 2500 to 4500 rpm range. That's the range i ride in 99% of the time.
Fenrirsmayhem
Jan 27, 2019 03:18 PM
sskimber
May 30, 2016 10:17 AM
Sharkman73
Exhaust System Topics
18
Sep 4, 2012 08:40 PM
jakerbaker01
11
Aug 31, 2011 07:15 PM
BaggerDave
Jan 8, 2006 07:21 PM
