I gave my EVO manual away with my last bike, But i believe the primary chain should have 3/8 in. movement at the tightest point. I allways just did it by feel. I'd get the chain at the tightest point and as long as I could lift it a little on the bottom and it had no slop It was ok. worked for me for many years.
Engine: 4 qts. w/filter
Transmission: 20-24 oz. (approx) - check the dipstick
Primary: 38-44 oz. (approx) - fill until oil touches the bottom of the diaphragm spring on the outside of the clutch-pack (and after you do any adjusting, of course)
The primary chain should have 3/8"-5/8" of slack hot, 5/8"-7/8" cold
loosen the bolts on the shoe and move it up or down to obtain the correct slack.
Note: these figures are right out of the shop manual.
